skipcurt
Skip
Sweeeeet! Thanks T_C. I'll be waiting for your post or PM. Hope you can find it.I do actually. My gf's ex wanted me to order one for him. Now he doesn't want it. Go figure. ;-)
If I can find it... give me a day or two...
Skip
I come up with nothing when searching that. In fact, the only thing I get is that exact post from this thread.09139-05023 ?
or
5B4J 276966 ?
Either of these ring a bell?
First number pulls it.I come up with nothing when searching that. In fact, the only thing I get is that exact post from this thread.09139-05023 ?
Nice mod Mike.I have seen several members here that have lost their inspection covers along with the deflector cover. You can replace the inspection cover easy through Honda but try to buy just the deflector cover for this. Good luck as Honda wants to sell you a complete replacement deflector set at a very high price.
Incredible simple remedy to apparently common problem. Mine will be done when my parts from partzilla arrive. Thanks.I have installed the Honda Faring deflectors on my ST 1300. They work great and keep the heat off of you and they also look very nice IMHO!
I had a problem with one of my inspection covers on the right side as it started coming loose on the top of the deflector. This happened when I was using my ST on a Fire break road in Yosemite. I won't go into that story here.
Well here is an easy fix to secure your faring deflector covers along with your inspection cover. It is about a 10 minute fix after you have the parts.
Parts needed are 2 metal dowels about 1 1/2" long, the thickness should be about 9/64 to 3/16. The ones that I have installed are tapered 3/16 to 9/64. You do not need to get the tapered ones but I think that they work better than the same size dowels. I got my dowels at the local Ace Hardware store and you should find them at any hardware or auto parts store.
Tools needed are a drill and 9/64 drill bit.
I drilled the faring deflector cover first in the middle of the "V" section seen here
I then drilled the "V" section on the faring deflector on the bike as seen here
You can then reinstall the Inspection covers with the improved deflector covers and they will be nice and secure with the plastic pin installed at the bottom.
I hope this helps out anyone with the deflectors and I would recommend this fix even for new deflectors as they are a lot stronger this way.
Mike
I would hang on to them as they are getting so hard to find now.Just about to fit a new fairing deflector kit to my recently bought A9 ST1300. I will do the dowel fix before I attach the kit to the fairing so many thanks for the idea and the info about the fixings.
I also have an older 2002 ST1300 which is going to be replaced by the newer bike. This had the mirror deflection kit as well as the fairing deflection kit. The mirror kit is now impossible to locate so I removed that from the 2002 bike to put on the new bike. Removing the fairing deflection kit off the old bike looked as if it would be more of a job than removing the mirror kit so I thought I would treat myself to a new one (£170 from Honda). Having read this thread I am wondering if I should take the old kit off the older bike (which I plan to sell) and keep it as a spare!. What do you think?
You will never have a problem if you make sure the retainer rivet is not broken, is inserted all the way in, and clicked in place.Incredible simple remedy to apparently common problem. Mine will be done when my parts from partzilla arrive. Thanks.
