Headlight Bulb
Take two H4s from an auto store. break off the lower two tabs (that keep them from fitting) then put them in. Just make sure they are sitting properly. AND use surgical type gloves to put them in with. you don't want to handle the glass with bare hands!
For a 1300! the 1100 is from CB1100F if you remember those! THanks I bought one of those and it didn't fit because of the lower tabs. Now I am wiser!
Thanks!
Thanks!
Usually best to replace both at the same time, or you could have different shades (color) of headlights...
Thanks!
Never touch the quartz envelope on a halogen bulb with bare hands. If you do, wipe finger oils off with alcohol on a clean rag (better uses have been found for the stuff). Finger oils on the 'glass' will cause the lamp to fail as quickly as 2/3 of its rated life.
