Having finished rebuilding the front forks, now is the time to re-grease the steering neck bearings, if needed. I have a 2001 with 26k miles. I'm sure the mileage is okay, however concerned the time interval, may have given the grease time to dry out. The swing test from side to side evidences no bearing wear.
What is the general consensus of relubing the neck bearings as regular maintenance, interval etc.?
Do the seals need replacing as part of the bearing lube maintenance?
Is there an upgrade to better bearings?
TIA
TIA
