No air should get in doing that,
any minuscule bubble of air in the new bleeder
British Columbia (1) UK (O)
I demand a recount!
Thanks for all the responses guys. Looks like the Motion Pro is probably the easiest and most economical way to go (and Since Igofar recommends, it should be good enough for me).
That's the tool! I purchase 3/16 x 5/16 clear tubing at OSH (orchard supply hardware). You can probably get it at any hardware store.
They provide cheap, flexible tubing soft enough to use their shrink wrap on the packaging. It does not work well when used, so throw it away before you start.
I also have never had to use the clip with good tubing.
Good luck with your brake service, if you need help, just ask.
SpeedBleeders are great. I have installed them on both an ST and a GL. Put them on individually and in the order Momma states. Make sure you start off with the reservoir as low as possible but short of sucking air.....
You can still correctly bleed linked brakes with speed bleeders. The system has to have speed bleeders in all brakes( and clutch) if you want to bleed/renew your hydraulics quicker. Follow correct order as per manual.I never went to speed bleeders because of the linked braking system. The line between the front and rear brakes needs to be bled correctly and the only way to do that is to follow the Service Manual instructions and use a vacuum bleeder which pulls the fluid through the system.
