Thanks to Dave and Steve who helped yesterday when I was stranded after lunch with a key that won't turn my ignition any more. It's the strangest thing...
Key is in good condition and, in fact, this is a new ignition that was replaced a little over two years ago due to strange electrical issues. In retrospect, I probably didn't need a new ignition back then and it was probably only the ground problem I had that was subsequently fixed. The dealer will probably say, "replace the ignition" again.
So, both keys are in seemingly good shape, they go in normally, but it's as if it's the wrong key. I've looked a few times to make sure I'm on the right bike, but it is. Even the spare key has the same issue. Keys go in, but won't turn. They wiggle a bit, and believe me, I've been wiggling them carefully and otherwise for hours now.
I tried some graphite-based lubricant today. 3-in-1 Lock Dry Lubricant was recommended by a local locksmith, but that hasn't worked yet. I guess I have to get a mobile locksmith out. And that won't be cheap.
I read on a thread here of someone having a similar problem once, but taking my ignition apart in any fashion is way beyond anything I'm going to attempt.
Appreciate any advice!
