LeeWonnacott
My odometer has turned past 105,000 miles now and certain things give me subtle clues that my new bike is no longer new.
Until my trip to California in March I always wondered why everybody was complaining about heat on the heels and around the foot pegs. Well, a broken valve stem on the rear wheel forced a roadside dismount and remount. In the process the metal collar that holds the exhaust pipe flange tight to the muffler pipe broke... I'm sure this has happened to many of you. I bought and mounted an automotive U-bolt as a temporary fix. Heat on that side of the bike was a huge problem for the rest of the trip.
It wasn't until I dismounted the muffler to remove the roadside U-bolt repair that I began to understand why the heat problem can appear suddenly. The slip joint gasket looks like a small roll of duct tape. The center of the joint is wire mesh and it's wrapped with a heat resistant tape material. The OEM gasket can become brittle and melt the mesh. That's when exhaust gas begins to blow by and bake your heels.
Obviously Honda has figured out that the OEM engineering here was not stout enough. I ordered a new assembly from www.RonAyers.com and was pleased to find a wider, much stronger, collar.
The parts you need are the new collar; Honda P/N 18372-MAT-0001
a new slip joint gasket; Honda P/N 18391-MLO-003
and two bolts for each collar; Honda P/N 90103-KCM-620
It's a simple fix and can be done the next time you change the rear tire. BE CERTAIN to clean the inside of the flange before you put the new gasket in, otherwise you won't get the proper fit and seal. Rock the gasket slightly as you insert it to make sure you get it all the way to the proper spot. It's obvious when properly seated. When tightening the collar bolts be sure to snug one first, then the other, till fully tight. Do one all the way before going to the second and it will warp the flange - and you are back to hot gas blowing by the gasket. The process adds maybe ten minutes to a rear wheel tire change.
Took a quick ride - no more baked heel.
