Hi all,
I have been looking at buying an st1100 for a while now, and I've found one at £1000 (I'm in the UK).
It's a 1994 model with 41,000 miles. The seller has stated that the ABS light stays on, and I have read that you can hold down the ABS button, turn the ignition and get the fault codes.
My question is, which fault codes should I avoid? As I haven't seen the bike in person yet, I don't know what fault code is showing. I don't really want to be putting loads of money in to the bike, so if there are fault codes that are a 'no go' or things I should be worried about, then I will give it a miss.
The seller seems to think it might be a rear wheel sensor, which I have heard is a 6 flash fault code. Would this be something expensive to fix?
