The correct part number for your 04 ECM is 38770-MCS-L01... the same part number was used in the 03-07 year models. I went through the same FI26 error and my problem was the ECM.
I did take a pic of my ECM last night so I'm on the hunt for one if it's going to be needed. I should know for sure on Sunday.
As for now, I'm going to say this is solved unless anyone can think of any other tests to perform.
I recommend against soldering in automotive applications or anything else where there's vibration.
Solder bonds the strands in the wire together, which sounds like a good thing until you notice that the spot where the solder ends and the strands are free again becomes a stress point. It's better to have the strands free to move and be elastic as they need to.
--Mark
Not sure what you mean by "both connectors" as there's only one diagnostic connector. It's red and located to the right side under the passenger seat.
Gotcha! Thank you for pointing me in the right direction. I saw what you referred to and confirmed in the service manual.
So I did that now too and took it out for a spin and unfortunately the dang light came back on again.
The ECM does not store a knock sensor error... when the key is turned off, it resets.
When I unplugged my knock sensors as a test for my misfiring problem the computer set an error code for both the left and right ones as soon as the engine reached around 4000 RPM. When I plugged the sensors back in the light went out, but the codes were still in the ECM before I cleared it.
We need a Honda engineer to answer this... the ECM on the 03-07 bikes obviously have some defect with the reported number of failures and Mother Honda seems unconcerned about it...
