The TPS is an input to the ECM, the "meter unit" is an output from the ECM, so any trash on the "meter unit" is not a factor, because it's not on an input. That's the way ECM's work.
FYI, Jeff's ECU has been swapped with known good units, with no success. Missfire stays with the bike, not the ECU. I don't think he's tried swapping speedometer units.
FYI/BTW : I found this doing a Google search. You can buy these for about $200 online. A super troubleshooting tool especially for bikes with an ECM.
http://www.hantek.com/en/ProductDetail_13_10163.html
for $200 a decent bang for the buck. In Jeff's case the scope trace quickly identified the nature of the problem, but without any technical support from Honda the root cause of the problem is still a mystery. All the test equipment in the world isn't enough if you don't know what you're looking at with a proprietary design.
edit: was searching on something else and stumbled upon this scope, for $350 I'd probably prefer it over the $200 one. Man, scopes sure have gotten cheap over the years.
https://www.tequipment.net/Rigol/DS1054Z/Digital-Oscilloscopes/?rrec=true
I get spoiled at work by Tektronix and HP/Agilent/Keysight scopes. At home I now have a hard time using my old Hitachi 60MHz analog scope. ;-)
Replace the O2 sensors and inspect wiring and plug connections. Not uncommon for them to fail.
speaking of HP/agilent, go pick this up for $40 out in Oxnard, sounds a little too good to be true, but its been on CL for almost a month:
https://losangeles.craigslist.org/sfv/ele/d/hp-3478a-digital-multimeter/6374811014.html
I'd rather have a 34401A. ;-)
why do you need 6.5 digits? Those also cost a LOT more than the 3478. I can't come up with a reason to even need 5.5 digits, but for $40 if its even close to being in calibration it would be worth it. If I lived closer I'd be a buyer, but don't feel like riding 200 miles each way to pick it up.
I just called the guy and he's going to ship it to me for $10, so I bought it. Now I'll be able to measure the voltage on my ST battery to 4 decimal places.![]()
