Thermostat Housing Q
There is a small cast bump - more of a low cylinder - on the outside of the spigot of the thermostat cover. I noticed a white paint dot (nice and neat like an intentional mark) on the outside of the radiator hose that fits to the stat's cover spigot. Are these supposed to line up - are they a guide to how the hose goes on the thermostat cover? The old hose had a white stripe that was positioned to align with this bump (well, pretty close - I made a mark and its slightly off).
How do you guys get the hoses on these fittings? After cleaning the metal the hoses fight me tooth and nail when I try to put them on. Do you use any kind of lube besides anti freeze? (Maybe its back to the gym for me.)
Same as the 1100, those hoses are a bear to get on. I used a water based lube (found near the condoms in a drug store) which won't leave any residue or oils to harm the rubber. Helps a bit.
I think you can see how the hose should line up based on the path it will take. If the marks line up there's your answer. I can't remember myself.
I generally just use a swipe of coolant to get a hose on but if it's really tough going I'll use a very light smear of SylGlide or similar silicone grease on the ID of the hose.
I've use WD40 to get my hoses on, I've never had any issue with them from using it.
And yes, the marks are to align the hose with the housing.
I've used KY jelly for a LOT of ahhhh nontraditional uses over the years. Didn't think about it this time.
I was afraid a dab of silicone grease would be too slippery and the hose would blow off while I was riding. Glad I'm not going where no man has gone before.
Thanks, Bob.
A short spray of Armor All or silicone based tire shine will also work, just use a finger to spread it around the ID of the hose. Don't get any on your tires.
