ST1300 Under Mirror Auxiliary Light Brackets, limited availability.
SoCalST8
Vendor
Los Angeles
ST1300, ST1100, R1
$79.95/pair Life Time Replacement Warranty*
For ST1300 Pan European ONLY. All years.
3d printed 100% infills ABS auxiliary light bracket
Utilize stock lower mirror mounting hole
Simple and Quick Installation
Sold in Pairs. BRACKETS ONLY with included stainless hardware.
Everything else in the pictures are for illustration purpose only, not included.
Please note irregular surface finishes due to 3d printing process
Designed and Made in USA. LIMITED AVAILABILITY
*Free damaged/broken bracket replacement, excluding shipping and handling.
https://psr-usa.com/st1300-unver-mirror-brackets.html
Charlie
Pictures of my own ST1300 used for R&D the 3d printed light brackets. The round, oval and rectangular LED lights are available on Amazon at about $25/pair.
Thank you for these under mirror brackets, I am absolutely loving them. Work great, look great, and very easy to install. No cutting of Tupperware. Lock in place against the mirror to body bracket.
I am also loving the over mirror brackets, can't wait for these to hit the market. People please let Charlie know if you are interested.
yes, we can US Mail to Canada. [h=4]First-Class Package International Service is about $16 USD.[/h]
Just received mine and installed. Took five minutes and look great. Thanks, SoCal ST8! Thanks for the heads up, Dave! Came nicely packaged with a sticker and a keychain, too.
Looking at picture #1 in post #7 above the bracket appears to protrude quite far back behind the mirror. Is there any possibility of stray unfocused light from the lamp mounted below shinning up and hitting the mirror? Or is it just the way the picture makes it look?
attachment.php
In this pic the light looks slightly forward of the edge of the mirror. I'm wondering if the brackets are of different dimensions of if it's a matter of angles. There was/is supposed to be a different (or updated) bracket to clear the mirror defectors.
Looking at Pic 1 in post 7 if the bracket was behind the edged of the mirror larger/deeper lamps could still be in front of the mirror and not an issue.
I can say for sure the bolt hole in the brackets is just behind the mirror housing so that the light is fully in front of the mirror.
The Leaning a little too far back issue has been fixed and never existed if you do not have the wind deflectors on your mirror housings.
hi amv606, has your order issue been addressed yet? if not, I can take care of it personally for you. Thanks!
Charlie
