I have heard that the string type tire plugs are better than the mushroom type but I havent seen any kits to buy. What are other people carrying and where did you get them??
thanks.
thanks.
Glad to hear you got back safely!
Mark
I have the gummy strings and a Cycle Pump on my bike at all times.
I have the original larger stop n go kit, and like it. I believe the only difference is the way the plunger that pushes the plug it actuated. In mine, it is pushed by a rod that is actuated like a caulk gun with a squeeze handle. The newer small kits I believe use a threaded rod that gets turned to push the plug. This makes it smaller and easier to pack. Ive never used one of the new ones.Thanks guys...
I was thinking of getting the combo from bestrest..
THE CYCLEPUMP, tire gauge and StopNGO kit .. but it is the cheaper stopngo kit? for those using Stopngo that works..... which one ?
I don't know what the string says, but the mushroom says it's only temporary... My rear tire is plugged with the string type without the cement and it works well. Only thing is, at speeds over 100 mph, I can feel it going around... bump, bump, bump, bump.....
Probably the best solution, if you are going to run a plugged tire, is to plug it AND patch it! JMO.
