Hello,
I recently had the shop replace the battery on my bike. I went on a 5 day trip where I experienced some weird little issues. Once or twice the electronic display dimmed out when I was starting the bike and once my trip meter zeroed out randomly. Bike was parked for a couple of weeks and when I tried to go for a ride the battery wouldn't start the bike.
Things done so far:
- Charged the battery over night on 0.75 amp setting which worked well. The battery was at 13.3 volts steady with no drop over 5 min.
- Performed the current leakage check; muti-meter in series on the negative side and a 0.8 reading with the dial set to 20m. Tolerance is 2.5 milli amps.
- Performed the charging system check; bike warm and running and headlight on high beam; multi-meter reading 14.2 VDC. elevated the RPM to 5000 with no change in voltage reading. Book says it should be 15.5 VDC.
- I'm going to pull the battery and bring it to the shop to have them do a load test.
My question is before I start removing side panels and such are there any other quick checks I can do.
Thanks in advance to all that reply
Pat
2003 ST 1300
Things done so far:
Pat
2003 ST 1300
