I bought an ST1100 year 97 that I am going to restore. It was very poorly maintained. I will be grateful if you indicate where the hose indicated in pictures 1 to 3 is connected and if the hoses shown in picture 4 are correct.
Hi Martin:
Welcome to our forum.
If you go and read this article: ST1100 - How to do an emergency bypass of the fuel valve, it will explain to you exactly what the previous owner did that resulted in the hoses looking the way they do now.
If you wish to restore the bike to exactly original condition, you will need to buy a new fuel shutoff valve and then re-connect the hoses in their original positions (shown in the above-referenced link). But, this is not "urgent" - the bike will run fine with the fuel valve bypassed, and it looks like you have other, more important things to spend your money on before you replace that fuel valve and return the hose plumbing to normal.
Michael
Thank you John for your detailed explanation. Seems you know the bike a lot.You are communicating just fine, Martin. Welcome!
My guess is that the unplugged hose in your first three pictures is the crankcase breather hose that connects to the bottom of the air cleaner housing.
The hoses in the fourth picture appear to be a bad repair of the #2 and #4 cylinders’ intake manifold vacuum port hoses (left front and rear cylinders). The front hose in your picture looks like the #2 vacuum port. It is plugged into a “T” connector like that used on USA models’. This T on ours links the #2 and #4 vacuum ports, with the third hose leading to and providing vacuum to the PAIR system valves under the carbs. The center leg on your T has a short length of hose that is plugged on the end. The other leg has non-Honda, clear PVC hose hose leading back under the carbs. I’m going to assume it is connected to the #4 cylinder intake manifold vacuum port. Please confirm. If not, what were they tapping vacuum from the engine for? And where is the #4’s vacuum hose?
If your ST was produced and manufactured for a market not requiring the PAIR system, I’m not sure what the fourth picture is showing. My guess is that you can just install your own new, quality vacuum hoses to each port and cap them with removable plugs. Make the hoses long enough to make it easy to do a carburetor synchronization.
A Honda Service Manual would be a great help to you I’m sure. Good luck with a worthy project!
Hope you get it sorted out and welcome to the forum!Thank you John for your detailed explanation. Seems you know the bike a lot.
I will continue disassembling the bike. It will take some time to disassemble the carbs and find if it is the cranks breather and the intake vacuum hoses bad repair. For sure the previous owner o their mechanics did a terrible work.
I will take pictures and inform my findings to you and all gentlemen who has collaborated in this topic.
No doubt I will find more doubts in my restoration progress and ask this forum.
So far I got the user and shop manual.
I need to find where to buy the fairing fasteners and whichever spare part I will need,... at reasonable prices.
Saludos (cheers).
Martin.
