My bike doesn't have heated grips. I want to buy some and put em on. Is this difficult to do ?? and maybe some recommendations on types to buy would be helpful. Never installed them before and this bike doesn't have them.
thank you.. I'll look em up. Also are they easy to installHeat Demon membrane heaters. Have them on the ST and the KLR. Never needed to have them on the high setting. The ones on my ST are 15 years old and going strong. About $50.
+1 .. Oxfords are great and you don't have to tap into switched power as they will turn off automatically when they don't sense vibs from the engine..I bought my Oxford heated grips from Revzilla for $89.00. They have a good video on them. Very east to install. I have them on my ST. They work better than the OEM ones on my BMW and my Triumph.
Agreed that this is a simple install. I just question if they now expect the consumer to supply their own adhesive to adhere the heating elements to the bars or the intention is to use the heat shrink to hold them on.“Easy to install” is subjective of course but I think most of us are capable of installing these.
Andrew,Agreed that this is a simple install. I just question if they now expect the consumer to supply their own adhesive to adhere the heating elements to the bars or the intention is to use the heat shrink to hold them on.
From what I have been seeing the kit that you linked to is the old kit that has now been superseded by a new kit. The heating elements in the new kit no longer are self-adhesive and there are two pieces of heat shrink included now. With the old kit the heating elements were stuck to the bars via their own self-adhesive. The one heat shrink was intended to be applied to the clutch side if the bar was aluminum.
The heating elements are no longer self-adhesive and I saw pictures on a few websites showing the heat shrink applied over the heating elements, not under, on both the clutch and throttle sides but that doesn't really mean much as they were only advertising pictures- not install pictures. Without the heating element being glued on to the bar it doesn't seem like it would be a secure attachment. I think that I would glue them on. Unfortunately none of the sites where I saw these had the installation instructions available, which is to bad as I am curious to see what they say
Thank you for doing that Dave. I am glad to hear that as it didn't make sense to me.I received this reply from Tom at Symtec concerning whether or not the elements are no longer backed with self adhesive and require heat shrink over the heat elements.
Phil- out of curiosity what Symtec P/N did you receive?Just got in a new set
This is the main reason that I am looking at the Heat Demons- so I can put more comfortable BMW grips on. I find all of the aftermarket heated grips are rock hard and I see no reason why they need to be. I had a set of Hot Grips on a previous ST1100. They worked really well and got really hot really fast. The problem was they were rock hard to the point my hands hurt after long hours whereas they never did with the Honda OEM grips. I do wear gloves all the time. Why can't they make them with more comfortable grips?The only advantage the Heat Demons grip liners have is the ability to chose your own grips.....the Bikemasters are hard rubber that I am OK with as I always wear riding gloves.
...Why can't they make them with more comfortable grips?
