lrhsr05st1300
sirlancealot
which angled valve stems do you recomend/use??? i seem to have a lot of trouble with the stock ones
These are nice stems especially of you're not going to be adding a TPMS sensor to them. There's nothing preventing you from adding one to these stems but there is some inconvenience of removing the sensor to add air and not knowing how much you've added until you put the sensor back on. Then you might have to add more are or bleed some off. Not a big deal but if you have or might be getting a TPMS eventually the T-valves are the way to go.Andrew Shadow said:
You're not alone. If it's going to be some time before your next tire change you might get a curved valve stem adapter as an interim solution. Screw this on your current stem when getting air and remove it before going in service. The adapter is not meant to stay on while riding as it will damage rubber stems.i seem to have a lot of trouble with the stock ones
thanks i just ordered a setThese are nice stems especially of you're not going to be adding a TPMS sensor to them. There's nothing preventing you from adding one to these stems but there is some inconvenience of removing the sensor to add air and not knowing how much you've added until you put the sensor back on. Then you might have to add more are or bleed some off. Not a big deal but if you have or might be getting a TPMS eventually the T-valves are the way to go.
You're probably already aware of having the angled stems installed facing to Port-side for easier access.
You're absolutely right of course. For some reason I was off course. I'll correct my post.Kevcules said:I installed mine facing the starboard side.
Remember that "port" and "left" are both four letter words.You're absolutely right of course. For some reason I was off course. I'll correct my post.
Thanks but that only helps if you don't know the difference between port and starboard and not if you're just experiencing a drift factor.Larry Fine said:Remember that "port" and "left" are both four letter words.
I understand now: you remembered which way port is, you just forgot which way the bike leans.Thanks but that only helps if you don't know the difference between port and starboard and not if you're just experiencing a drift factor.
Close! I'm thinking the bike is leaning to PORT and the valves need to point 'opposite' and not STBD.you just forgot which way the bike leans.
Is the bike pointed true north? And why do the Brits go by coast guard rules passing starboard to starboard?Close! I'm thinking the bike is leaning to PORT and the valves need to point 'opposite' and not STBD.
These are the wrong size for the ST series bikes and they don't seem to have the correct size listed.
I didn't check it close enough. ThanksThese are the wrong size for the ST series bikes and they don't seem to have the correct size listed.
I use this positioning as well, but only use the center stand when doing certain maintenance work. Right handed also being the reason.I always park my ST on the centerstand. I am right handed so I put the front 90 degree stem to the port side and the rear to the starboard side. Makes checking air pressure easier.
