So i like this thread and setup...
What im doing is slightly different:
- Kenwood TK-8180-K 40w 2-way radio base (in rear hood) with KRK-10 remote display kit (mounted on RAM ball off bars riser base) and mic mounted on handlebar
- Pryme BT M31 Kenwood db25 aux port to wireless adapter (similar to Sena SR-10, but with dedicated 8180 cable and connector), and remote wired PTT jack.
- Pryme BT PTT2 push to talk remote button
- Kenwood wired PTT button with cable and jack.
- Sena 20s BT wireless helmet mounted comms system
- Kenwood TK-3180-K3 5w 2-way radio portable (belt clip) with KMC-41 noise canceling mic mounted on shirt lapel (note that mic has earphone jack which can go to the helmet)
- Honda ST1300-PA with PTT on left handlebar grip switch base, but not wired up currently
The TK-8180 to Pryme-M31 to Sena20s works fine once the pairing dance is setup, and 8180 aux interface programming. The wireless PRYME PTT2 works with the M31 too; but for some reason affects the mic quality. I think its pairing wrongly. Thus ultimately ill run this radio with a wired PTT. The wireless PTT2 might be something I wear in case I need to key this radio when off the bike directing traffic.
Typically, I use the TK-3180 portable when off the bike and when reaching the mic is safe. Doing this while riding is dangerous and the wind noise overwhelms the voice input past 30mph even with a noise canceling mic.
Moving the 8180 to BT and a PTT run Sena20s boom mic and helmet speakers will eliminate the hand mic and the display head's speaker which is virtually un usable past 30 mph, regardless of the fairings and windscreen.
You might be wondering why two radios, one is good really only for line of sight and is portable; while the other is not portable (but is mobile) and can reach trunks and repeaters to the comm center much further away. LA highways and city buildings environments are tough on reception, especially for mobile and noisy applications such as on a open cockpit motorcycle with limited ground planes (RF stuff). What would help is digital UHF radios, but the switch would be painful and expensive not being taxpayer funded.
I still wonder if the SR-10 would interface with the 8180 or 3180.
Update:
This suggests it is not compatible with either Kenwood i use:
https://support.sena.com/hc/en-us/article_attachments/209751126/SR10_2-Way_Radio_List.pdf
but that one could make their own cable to make it work knowing the pinout:
https://support.sena.com/hc/en-us/article_attachments/209751106/SR10_Cable_Pinouts.pdf
