No more ten point turns to be able to ride out of a small garage. A 1000lb capacity 12" lazy susan from Amazon $14.00, 14" metal cutoff blade from Harbor Freight $4.00, 14"x8" pc of 3/16" steel plate from eBay $25.00. The wood pieces keep the bike from sliding on the steel plate when putting it on or off the center stand. Even though the total thickness is only 5/8" it does make it more difficult for my 70 yr old body to get the ST up on the center stand so I roll the back tire up on a piece of 3/4" plywood before positioning the turntable. Press down on the back of the bike to balance both wheels off the ground and rotate the bike 180 degrees and go. It's compact size can be stored easily.
