I try that, ThanksLooks like you can set-up to test
You can but no use. File it down as in the instructions and put the nut on as tight as you can without stripping it out, which is easy to do. Once it is on I took a small amount of JB weld and put it on the nut and shaft, and then on the arm and spool where they meet. I never plan on it coming off but if it really had to i could get it off. I will look for a photo if I have one. An alternative is to make your own arm off the pattern of the futaba arm with thin aluminum plate. I have seen that done as well.Can I Skip the Futaba Arm ?
I installed mine lower than in this article and with the cable pointed horizontally, but I don?t know if Honda speakers will fit.
Here is a momentary switch that works well on the ST throttle housing. I used them on a previous cruise install.
Has any one wired the clutch safety switch . to disengaged the Rostra when the clutch is pulledTo view this article, click on the link to the attached PDF file.
Rostra cruise control installation by altexst1300.
I did on my '96 NH750ST. Worked perfectly with mo modification. I even wired a tiny relay to cancel the cruise when I hit the center switch on the control switch pod I used.Has any one wired the clutch safety switch . to disengaged the Rostra when the clutch is pulled
Has any one wire the clutch safety switch into disengage the RostraTo view this article, click on the link to the attached PDF file.
Again, I did. What's your reason for asking?Has any one wire the clutch safety switch into disengage the Rostra
