ST1300 Oil Viscosity and brands recommended
I've always wondered why the inside surface of the oil pan isn't angled like institutional shower drains (no I haven't done time).
Because it doesn't matter in the scheme of things, if a few ml of oil doesn't drain out its not going to make any difference. There's plenty more hiding in crevices throughout the engine that doesn't drain out either, so no sense being anal about the last few drops.
010688
But wait! There's more!
About 357 more. Now much would you pay? These are listed as replacements (their quality and your mileage may vary. :D) for the second filter dd showed. Like it the Bosch 3323 is a little longer than the ST1300 factory filter. I fill it with some oil during a change to give the pump a 'head start' Just because it makes me think I'm really 'wrenchin'.
I also tell myself I can put a whole gallon of oil in the bike because of the extra room in the filter and that I don't wait to drain every last drop from the jug. Checking the level the next morning I found it to be at the upper limit line so I don't worry. When draining, I do stop for a sammich to let it drain until it won't. I've always wondered with the inside surface of the oil pan isn't angled like institutional shower drains (no I haven't done time).
Well, he did ask for the OEM reference number. That narrows the 357 down some.
Lake Zurich, Illinois
04 ST1300
Would Shell Rotella T6 Full Synthetic Diesel Motor Oil SAE 15W-40, work in a st 1300. Does it have the required ratings. I rarely ride below 45 F and change oil and filter every 5K. Would there be any starting issues, due to oil thickness. I currently use the valvoline 10w-40 motorcycle oil.
Kevcules
NB Canada
2008 ST1300
No Issues. Regular petroleum oil in cars that run 5w30 can somehow still lubricate and let an engine start in -30 degree celcius weather.... You're fine.
st11ray
charlotte, nc
'06 ST1300
7189
Just use the T6 5W40.
I noticed. Not so coincidentally it's the number used to get the 357 additional filter numbers. I was just riffing off his comment I quoted. Maybe that could have made that more obvious with "there are more filters in heaven and earth Duporth than are dreamt of in your philosophy".
st11ray
charlotte, nc
'06 ST1300
7189
Why not 15w-40. I dont need the thinner oil as I never run below 45F. Also, some folks said the 5w-40 can get a "little notchy". Any thoughts on that.
I've used the T6 5w40 for quite a while. I change oil every 5k. It shifts fine.
Duporth
Australia
2021 BMW R1250GS
:) I wonder which 10 oil filters (for want of a number) of the 357 might be rated "best" for the ST1300 application?
I will never know.
My default position has now become: use OEM.
D
Los Angeles, CA
One more Rotella T6 full synthetic and Purolator L14610 filter (in both 1100 and 1300). They're both excellent quality for a very reasonable price.
Bought a Used ST1300 2006 and runs like a champ; Please confirm we are using Rotella T6 (the bottle reads for Diesel Engines)?
04 ST1300
While a lot of people use this oil in their ST's and I was thinking of doing the same starting this year. Is there any concern as to the caustic content in this oil as compared to non-diesel oils. Diesel fuel has a higher amount of caustic to offset the higher acidity caused by burning diesel fuel.
kankakee
R1200rt
yes and no
Southeastern corner of Arizona, planet earth!
05 ST 1300 hack'd
I have indeed read that diesel oils do have additives specifically to neutralize acids formed as combustion by products, inherent to diesel fuels and their sulfur content. I read that a while back,on the BITOG (Bob is the oil guy), website.
Rick.
04 ST1300
That is quite a short interval. The maintenance manual says to change oil & filter every 8K miles and this is with conventional oil. With synthetic you should be able to go at least 8K and maybe even 10K.
st11ray
charlotte, nc
'06 ST1300
7189
It makes it easy. I know to change my oil at every 5k mile interval on the odometer. And since a gallon of oil and a filter is only $25, it's not very expensive either. I've been doing it this way for at least 20 years so I'm stuck in my ways.
