Pop-Pop
- Joined
- Feb 29, 2020
- Messages
- 2,454
- Age
- 68
- Location
- Pagosa Springs Colorado
- Bike
- 1996 ST 1100
- STOC #
- 9037
Does anyone know how i can install a waterproof usb (3) hub in my panniers without spending a ton of money?
Maybe a somewhat better idea...how about running a line from the battery (SAE cord) to one of the fairing pockets then connect a SAE charger to it that can charge via USB to your phone. I know Deltran sells one on Amazon. I have one but never hooked it up (maybe minimal drilling to make room in the pocket for the cord). Alternate route...buy a multiple charge extended battery (also on Amazon) and this way, there’s no wires to run. Connect to your phone and you have power (and for multiple charges via USB. I think trying to run a line to the saddlebags is much more difficult.
Alternate route ... buy a multiple charge extended battery
+1.
I vote for the Anker PowerCore 26800mAh.
ThisAnd a USB port in a pannier wouldn't need to be waterproof, only the wire entering it would.
...thisPutting plugs into the saddlebags is not complicated but it can be an opportunity to create leaks and issues when you want to remove them.
...this. I'm a fan of Anker products (except for anything audio of theirs) and a power bank is a quick and easy solution.I've been an exceptionally pleased customer of the Anker products for almost ten years
Hey, don't feel bad at all. If you're 64 and still camping out, you deserve respect. I'm 65, and I gave up sleeping on the ground 25 years ago... I guess I'm a wuss, 'cause it's hotels only for me when I travel. I never could get used to waking up in a puddle of water with a sore back, suffering from the onset of hypothermia...Technology is something! I def feel 64 now!
When that happens when you're in a bed, then you're old!I never could get used to waking up in a puddle of water with a sore back, suffering from the onset of hypothermia...
66 and still camping.... Try a better tent and a good sleeping pad. I was out west for a week and found 3 great free campsites. Camp free and you'll save more money.Hey, don't feel bad at all. If you're 64 and still camping out, you deserve respect. I'm 65, and I gave up sleeping on the ground 25 years ago... I guess I'm a wuss, 'cause it's hotels only for me when I travel. I never could get used to waking up in a puddle of water with a sore back, suffering from the onset of hypothermia...
Michael
Where do they get URL's like that. It's a mouthful!I have a small camping LED lantern that uses aa batteries. Works great in the tent. I change the batteries once a year. I don't leave it on long and have no need to. Its suppose to last 25 hours,,, And I recommend trying some of the free camp sites. Great way to save money and some of the places are pretty unique https://www.amazon.com/atenuable-re...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
The one I have is similar but I can't remember where I bought it. Tried to find one, my bad didn't read all the specsWhere do they get URL's like that. It's a mouthful!
BTW, it says it uses 3 x D batteries.....must have updated the Lantern.
Never got any water in the pouches but better yet is get a tank bag....and don't forget the power cable https://www.amazon.com/Battery-Tend...Q03NHK0R5WV&psc=1&refRID=GXXN73RS2Q03NHK0R5WVI agree with everyone's suggestion for a battery bank as a solution. I've been an exceptionally pleased customer of the Anker products for almost ten years. Well made, great performance.
I see you have the Hondaline Backrest? I use the same SAE cable I use for my Battery Tender to power a compact SAE USB power port, which stays under the seat. I then run the USB cable between the seatbase and tailsection into the pouch behind the backrest to charge my phone and other devices while on a ride.
LightningFast SAE To USB Adapter Motorcycle - Quick Disconnect Plug - Quick Charge 3.0 - Dual USB Ports To Charge 2 Devices
This one has two ports - one of them Quick Charge 3.0 plus the other is 2.4A. It has its own power switch (it does draw power when not in use if connected directly to the battery). Not a problem if connected to a switched SAE connection. Also extremely easy to just unplug from the SAE cable. Mixed reviews on Amazon. I've had two in constant use for the past two years with no issues.
I know the pouch is not waterproof, but a 1qt or 2qt ziplock bag should protect your gear pretty well. You're going to need a means of charging your battery bank anyway.
