Lake Michigan Iron Butt
Northern Baltimore suburbs
ST-1300A '09/'12
Two days ago I attempted to do an Iron Butt Saddle Sore (1000 mi in 24 hrs) around Lake Michigan by heading north up the western shore then back down through Michigan and returning to Chicago.
The plan was to leave Chicago around 4-5 am and get cracking early. Well, I didn't leave the house until around 5:45 but that was still early enough to miss Chicago's rush-hour traffic.
The trip:
A. Chicago to Peshtigo, WI - 245 miles, ~3.5 hrs.
I filled up and got a fuel receipt at the local Shell and was on the road at around 6:00 am. This was my longest straight leg, probably because I was excited and rested. I was slightly worried about hitting traffic in Milwaukee and/or Green Bay but needn't have worried. It was smooth sailing.
B. Peshtigo, Wi to Manistique, MI - 118 miles ~2.1 hrs.
A fill-up and 20 minutes later I was back on the road. About 20 minutes in, I got a "low battery" indication from my phone. The phone was hard-wired to the motorcycle but apparently had gone kaput. My back-up 12V accessory plug with a USB adapter also wasn't working. This sucked since I was using my phone for GPS directions and, maybe, more importantly, entertainment. Fortunately, I had brought a lithium-ion battery. So, I pulled over, got the battery, stuck it in the glove box, and connected it to the phone. Problem solved! Except that my main reason to bring the battery was to recharge my Cardo headset if need be (the second part of the entertainment equation.
C. Manistique, MI to Vnderbilt, MI - 141 miles ~2.3 hrs
This stop was a bit longer (1/2 hour) as I decided I would try and jury-rig a hard-wired connection. After getting gas, I bought a cigarette adapter that has a USB outlet and two wired females (basically a cigarette-lighter Y with a USB outlet). My plan was to cut off one of the female plugs, wire that directly to an unused portion of my add-on accessory fuse box, plug the adapter in, and connect the phone to the Frankensteinian mess. However, when I looked at the wires, I realized there was no way to tell which was positive or negative and, as I didn't have a tester with me, I'd be guessing. I decided to take my chances with the li-ion battery.
I stopped at a Mackinaw bridge lookout point on the Upper Penninsula:
And then again from the Southern Pennisula:
It was as I continued south that I remembered that you had to take a picture of your odometer as well as your receipt for validation. I'd not taken any pictures of the odometer. I was just over 1/2 way done and realized that I wouldn't be able to get the trip validated. Damn! Oh well, I guess the satisfaction should be in completing the event, not the recognition. Dammit, anyway! :mad:
D. Vanderbilt, MI to Bay City, MI - 127 miles, ~1.6 hrs.
I grabbed an odometer/receipt pic anyway even though I figured it would be for nothing since I couldn't verify the 1st half of my trip. The leg was pretty uneventful. Just followed the fastest traffic I could find and bolted down I-75. I gotta say, these ST-1300s sure eat up the miles. Really smooth. I had to constantly ease back on the throttle 'cuz I didn't realize how fast I was going.
E. Bay City, MI to Toledo, OH - 139 miles, ~ 1.8 hrs.
After fueling up at the Meijer I stopped off at McDonald's to grab dinner. At this point, I began to formulate a plan. The first stop I could validate was Vanderbilt, and I could get my wife to sign a witness sheet and that would validate my starting point. The only problem was that google maps would show the best way to go would be to head south under the lake and then back up on the Michigan side. This, plus my travel back to Chicago would put me short of 1000 miles. So I decided to detour via Toledo, OH, and reassess once there. My Cardo's battery was calling "uncle" by now so I switched the Li-ion battery to it. I decided to switch as needed rather than have wires run from the phone mounted between the handlebars, the battery, and my helmet. It worked out pretty well.
F. Toledo, OH - Warren, IN - 128 miles, ~ 1.8 hrs.
A quick fuel stop outside of Toledo and time for some soul-searching. I realized that if I headed straight back to Chicago, I'd still find myself short of my, verifiable, 1K by about 70 miles. If I headed back by way of Indianapolis I'd have more than enough miles under my belt. This was probably the most difficult choice I had to make. Do I head straight for home and fall short or push on? Logically, it should have been a no brainer and it probably would have been 8 hours earlier. But I was tired, it was getting dark (probably around 9 pm EST) and even though I was sort of heading home, I wasn't directly heading home. Had I not already committed to going as far as Toledo, I probably would cut my losses, thinking, "at least I know I did it," and took the shorter route home. Instead, I thought, "F*ck it," told my wife not to wait up and pushed on. I did many times, however, question my decision.
G. Warren, IN - Indianapolis, IN - 88 miles, ~ 1.2 hrs.
At this point, I think, this stop was to vary things up and keep my mind fresh. It was the shortest leg in both time and distance and I probably wouldn't have done it earlier. I can't really even remember the gas station at this point, so it was probably unremarkable.
H. Indianapolis, IN - Chicago, IL - 174 miles, ~ 2.4 hrs.
Stoped in a Marathon for fuel. It was completely empty and I didn't see anyone there. Most of the lights in the building were off but the pumps were still working. I didn't even realize that was a thing. I always figured that, due to liability, when the store was closed, so was the fueling. Guess not since I fuelled up and, with renewed energy as I was now directly headed home, I continued on my way. I made a quick pit-stop at a rest area, about 1 hour later, to grab a candy bar for a quick energy boost. I got to a Shell station near my house a little after 2 am and made it home shortly afterward.
Here is my final route:
Final Thoughts:
If I had to do it again, and I probably will (Bun Burner anybody?), there are a couple of things I might change:
  1. Back up GPS. I've always found that my phone was more than adequate for my needs. This was the first time that it, almost, failed me. Although I was prepared to buy a physical map book, it would have sucked to not have had the actual GPS track for posterity. My hesitation has always been that it's one more thing I'd have to carry with me as I'd not feel comfortable leaving it attached to the bike in a city like Chicago. That being said, the Li-ion battery held up great and had no problems keeping my phone and Cardo charged for over 500 miles! If I do get a stand-alone GPS, it will have to give me the option to record and save a GPS track and store mp3 files on board for entertainment. The latter might not have been a priority until this trip. :D
  2. New seat. Or, possibly, a seat cushion. My butt was getting a bit sore by the 5-6 hundred mile mark. I was really squirming by the last 200!
  3. Cruise Control. I'm starting to be convinced that this is a must for long-distance riding. My wife and I towed our boat around 500 miles a couple of weeks ago and I didn't use the CC 'cuz I didn't want to strain the truck's transmission but boy did I miss it. CC on a bike seems like a no brainer now. I did have a throttle-assist device (see below) that lets you use your palm to control the throttle, easing the strain off your wrist. It was definitely appreciated, but it's not the same as true CC. Also, it interferes a bit with your throttle control when you are not cruising. I think an MC Cruise is in my near future.
So that's about it. It was fun to do, but I'm glad it's over (for now). Another thing I might mention is never to underestimate the value of heated gear! Even though it's summer, it started to get cold when riding at night. One option is to layer up, but by having heated gear you only have to do it once and can turn it on or off or increase the heat as needed and not have to stop. Having the gear probably saved me over 1/2 hour not having to pull over to change layers.
Now I just have to gather all my paperwork and send it off to the IBA. Hopefully, I haven't missed anything! :confused:
Congrats Nexus! Great write up on your adventure. While I enjoy long rides I doubt I'll ever do an IBSS. I admire those of you that do take the challenge, though.
Sheriff
Sounds like you're missing a lot of documentation. If you didn't get a starting and ending picture of your odometer, then you may be out of luck. I'll be interested to see if you get approved.
How did you GPS trace your route? In the past, I've used an app called FollowMee, and I had to submit a link to the trace map. Nowadays, I have a SPOT X tracker, and can keep an historical record on a Spotwalla page.
I'm glad you had a safe ride. The very first time I did a SS1000, I forgot some documents as well and couldn't get the ride officially counted, but I still had a good time, and it sounds like you did, too!
Great write up and great accomplishment. As long as you know you did it, IBA does not matter. Did that back in 2017 but came back via Grand Rapids then Gary back into IL. Total route was about 975 miles.
I can highly recommend the McCruise. Plug and play. No hacking of the OEM wiring harness and excellent instructions. I know others have used the Rostra and Audiovox and I commend their know how.
The McCruise is more expensive but was worth every penny to me.
McCruise is Uncle Phil approved and recommended on ALL his bikes.
I got everything after the 500-mile mark. The IBA has an "Alternate Witness Method" where you get a witness (spouses allowed) to sign that you were in such and such a place at such and such a time. I can use that to prove I started where I did and, using receipts and pics, that I was ~400 miles away around 9 hours later. I can document everything from that point on. I'm hoping it's enough since even the stops I did document total to more than 1K. With receipts and GPS tracks, I can show the entire route.
I just used google's timeline feature and exported it as a .kml file. You can then import the data back into google/mymaps or any other GPS software. You can even convert it to a standard GPS file. You can then supply a link to your map.
I plan on it having three layers:
  1. The actual route followed (the GPS Tracks)
  2. The actual route followed using google directions (should show ~1200 miles)
  3. The route shown by google if you just plug in the verifiable waypoints (should show ~1040 miles).
Hopefully, that'll be enough.
Here's hoping...:)
(Love your avatar, BTW)
That was closer to my original route. I had also planned to stop in Sault Ste. Marie but inexplicably forgot to do so, which resulted in about 100 miles less of road. Which is why I had to detour so much! :cool:
Here's hoping...:)
The nice thing (as I learned) is that even if you end up not getting this ride certified, you can always do another one. :thumb:
Don't let anyone poo-poo you about doing an IBA run. There are a lot of people who don't get it, and that's fine. I'm waiting until the weather cools down a bit, and I think I'll take a crack at a BB1500 Gold. Then I'll have to update my license plate frame. ;)
(Glad you like the avatar. Not many people get the reference.)
I had forgotten all about Google's timeline feature. There are so many cell service gaps where I live that I've stopped counting on Google as being reliable for anything. It would be nice if Google had designed it in a way as to record your lat/long in memory until you're back in service, and then update your location accordingly. In my experience, I end up getting jumps in location tracking. That's one of the reasons why I started using a SPOT tracker (my wife gets a lot of peace of mind knowing that "as long as the little dot is moving, I know you're okay").
I remember after my last SS1000, I ended up sending a huge zip file to the IBA with enough documentation to choke a camel. Many find that level of documentation anathema to enjoying a motorcycle ride, but I enjoy the process.
Now that you've established that you'll ride long distances, you'll need to ride down this way and I'll show you around a bit. :thumb:
Uhmmm... Not just yet. ;)
Kinda sounds Insane. But, I guess I was close with 4 hours and 300 miles to go. Less stops and more interstates and it's totally doable.
I thought Google already did that. It would save the tracks until back in service. I remember someone marvelling on how Google had continue to track them on a boat outside cell service. I figured the phone probably stored the tracks until it could upload it to the cloud.
Yeah, my wife and I were going to join a group crossing from Ft. Lauderdale to Bimini in our 19' boat this summer but COVID. I was going to buy one for added safety. That would be a good secondary useage for one. She was able to follow my progression somewhat as we share our locations through Google. I guess the big problem with just using your phone is that all your eggs are in one basket.
I'm toying with the idea of going back to Deal's gap and touring the surrounding areas. Does that count? :biggrin:
Deal's Gap is a tourist stop - go there once to say that you did, and then go see the other, better places. ;)
Lots of beautiful areas to see down here. If you're ever planning on heading this way, drop me a line. I'll be happy to show you around.
Hmmm. Now you have me second-guessing. I've never been able to get that to work on my end. I get gaps in tracking, which show up as long, straight lines.
Oh well... between Googley Maps and the SPOT tracker, I get what I need. :thumb:
I made a similar trip back in 1980. I was in Wheaton IL so it was only 950 miles but well under 24 hours. I left on the spur of the moment at 10 PM. I headed up the west side and half way up slept a couple hours laying on my bike freezing. On the radio they said it unexpectedly dropped to 30 degrees. I pushed on though, made it around the lake, got back the next afternoon, took a shower, and drove to O'Hare airport to pick up my girlfriend now wife. I cut that one a little too close.
Now I too have the luxury of heated gear. The other huge advantage with heated gear is you don't need the bulk of several heavy layers. Less to pack, and less to restrict your movement.
Terry
The trip:
Final Thoughts:
These two items help me on the long rides...
or you can find anything similar........
I did this same trip :) Only the day i Attempted it was 98 degrees so once i hit the UP i got a hotel in Mackinaw
i decided my safety was more important then bragging rights i was physically exhausted from the heat
my GPS told me i was moving for 17 hours and traveled just over 1000 miles MINUS the overnight in Michigan
beautiful ride the west side I hit the Highway on the east and flat out ran :)
Over all fun trip
Terry
10 pm!? That sounds nuts! Well I do remember being much younger and leaving for a 750 mile trip on a very hungover morning. I think I made it in under 12 hours because I had to catch a ferry at the very end that only departed every 12 hours. This was on a "crotch rocket" no less!
Yeah, that might be in my future! :)
I have the sheepskin buttpad. I love it. The one for the st1300 completely covers the seat. It is a tight fit on my Sargent seat. Make sure you check to see if it will fit if you have any other custom seat.
i'm very late in reading this post but wanted to know if you got approval from the IBA?? Jim V. did an IBA group ride around lake Michigan back in june of '16, i was part of the group and finished in about 19hrs. in july i modded jim's lake huron 1000 and got an IBA cert for that. i had already done the lake superior and lower great lakes 1000 on my wing. i might do another lake michigan IBA 1000 with my niece, she wants to get a plate backer for her bike and i need / want one for my ST 1100
