- Joined
- Feb 11, 2006
- Messages
- 8,057
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2025 Miles
- 008576
Honda doesn't use the swing-to-the-side method of checking steering bearing preload. They are much too precise for that. The Honda factory service manual gives us a specific sequence of initial torque to 18 ft lbs, release, retorque to 11 ft lbs, then another 45 degree on clockwise on the adjustment nut. After staking the lock nut in place and assembling the top bridge the steering stem top nut is torqued to 76 ft lbs. After putting the forks and front wheel back together, a specific pull force test on one fork leg with a range of 2.14 to 3.2 lb/ft tells the tale. A trigger pull gauge is good for this. If it's out of that range then it all comes apart to retorque. The best thing about using OEM ball bearings is the service manual torque values are accurate and the trial and error are minimal. If you use aftermarket tapered rollers the preload settings are a crap shoot of trial and error to get the pull value correct.I have installed tapered steering head bearings on 3 different motorcycles. 1978 SR 500 Yamaha and added Zerk fitting to swingarm. All to improve handling and movement of parts that are supposed to move. Seat of the pants impression, seemed to help.
Also a VTX 1300 and a 2014 Valkyrie 1800. Both bikes exibited low speed occilation from 45mph down to 30mph. Success, improved both.
One thing i never understood was the complicated procedure for torqueing steering head bearing. Wheel bearings replaced is usually a two step process. Tighten to a pre determined tourque, loosen and final setting.
Seems most factories today use guns to fasten everything. If someone is doing the swingaway test to every motorcyle wouldn't that clog the line. They of course have the advantage depending on the level of assembly reached at that time. If someone could enlighten me I'm willing to listen.
