Uncle Phil
I bought a o-ring kit from my local autoparts that had way more sizes than I needed, but I was able to find the right ones in it for my MCCruise Vacuum unit.
Well it only took a little over three years after my initial post that started this thread. Pulled the CCS-100 unit today (this thread was useful CCS teardown). All the boards and O-rings were in pristine shape. Testing revealed that the center solenoid (the one that actuates the vacuum) needed a little encouragement. A drop of Wahl's trimmer oil did the trick. Hope this lasts for a while.Yes there is. Mine quit working and it turned out that the solenoids were stuck. I disassembled the servo, tested each solenoid with a 12v battery and some jumper wires. All 3 solenoids clicked when energizing so I put a drop of 3 in 1 oil in each solenoid and it has worked perfectly since. The servo is simple to take apart just go slow and easy with the plastic release tabs, I found a thread about doing this on this forum.
Thanks. I have fully tested it under ride condition; holds speed uphill and downhill. Cuts out on front/back brake as well as clutch pulled in. The center stand was just a shakedown to see if the unit is back to life or required more tinkering.It is next to impossible to test the cruise on the center stand. Believe me I tried. Go out and ride it is the the only true test.
Yes. Tested it under ride condition as well. My remark was that it the center stand test did not seem to trigger this feature the last time it was installed. My conjecture is that the partial opening of the vacuum port meant that the throttle pull was not strong/quick enough to race the engine.I believe it’s a safety feature when the revs go super high without a load like pulling in the clutch it will shutdown.
