ECU failure percentage
Ottawa, ON
'04 ST1300,
Just wondering out loud here. There seems to be more than a couple of people recently with FI codes/ ECU failures. Now admittedly many more people will post when they have a problem rather than " hey, my bike is running fine". And of all the ST13s sold how many are on this forum?
Is the percentage of ECU failures still relatively low? Like 0.1%? Or more like 5%?
It's late
I'm tired
I need to go to bed.
I wouldn't lose any sleep over it. %5 is like 1 in 20,,,,, tain't no way there is that frequency of failure. All the units are getting older,,, and no electronics last forever. But I think your first number would be closer to reality,,, CAt'
I think it's quite low. (hopefully)
I've wondered if they can be repaired, instead of replaced with all our new technology these days. :)
I also wonder if Honda has a newer version of the module now, so it's lasts the life of the bike?
While my ECU didn’t fail I did have the FI fault at least three times requiring the 5 way connectors under the air box cleaned. A fairly involved job you might say hmmm
I wondered that once. I took the unit off my ST1100AY years back, The 1100 unit is up near the steering head if memory serves me correctly. It was in a two part, clip together, flimsy looking plastic case, which wasn't clipped together. It was filthy. Inside was a much more robust metal case with a lid with small removable bolts. Which I removed, expecting to find a circuit board with oxidised soldered tracks and joints.
What I found was a bath of epoxy-like resin, looking as shiny as it would have when it had just set. Here and there the top of the taller component just sticking out above the surface. Good luck repairing that !
Well made, well protected from the elements, completely fit for purpose. But if it fails I think a new one is the only answer.
edit - having just read the post before this. The reason I was looking was due to my dash lights putting on a light show for me. Havent got a clue what was wrong, but when I put it back together all was fine again. I thought at the time that maybe pulling the connector and putting it back again had cleaned the contacts.
During my looking to see how available a spare used ecu was ( NOT!) I came across this site claiming to be able to repair the ecu
On their site they claim to be able to also fix the Throttle Control sensor and the ABS computer.
And I knew about this site from before but strangely they have an ST in their list but they didn't come up in the search
I understand the point of the thread, more general "musings around the camp fire" than "does Honda have a problem that I should think about suing them for?" Someone pointed me at this thread, and, by-and-large, I agree with most of the replies... but it's probably worth a few "back of the envelope" calculations just to join in while we drink beer around the campfire.
That said, it's a warm Sunday here, and I've just finished building decking in the back garden, now laid in a hammock having the lovely MsHom hand me a beer once in a while... so, excuse the ramblings that will no-doubt be below...
ECU's / ECM's are mostly interesting to me, because they're the perfect blend of hardware, mixed with near-realtime software. Considering that the engine (in all vehicles) has certain manufacturing tolerances built in (pistons to a certain number of thousandths etc), the software has to be able to learn how it should operate that particular set of nuts and bolts. Any of you that have worked in a dealership probably knows that the first time you fire an engine after building a bike from a crate, it don't sound right at all, but then the ECU learns & adjusts, and all of this happens pretty quickly. If you think a brand new build sounds perfect on first fire, please go get your ears checked (or mine are just more mechanically sympathetic I guess).
What's my point with the waffle? Well, manufacturing tolerances, but also, software bugs. It strikes me that the most commonly reported issue (here on the forum) is code 25/26, and once triggered, no matter what you do, the ECU seems to remember it. That sounds like a software bug to me, which should be possible to find a workaround for.
What I found was a bath of epoxy-like resin....Good luck repairing that !
You'd be surprised the number of electronics that are covered in epoxy. Mostly it's weather proofing like the case you mention in the 1100, sometimes it's tamper protection. Nintendo include a JTAG on some of their circuits, but like to cover them with epoxy. A guy I know asked me some questions about how to get at the JTAG so he could let his kids play hacked games... after the conversation of "don't developers deserve to get paid"... I told him how to safely heat it up & work with it. He apparently got bored, and used a paint stripping heat gun. Next day, he comes to me with "I followed your advice, and all the components dropped out of the board!"... "Err, that wasn't my advice, ain't my problem you're impatient!"
Epoxy resin isn't a show stopper, it just makes the job 1000x slower.
So, back of the envelope calculation time...My STOC # is 9004, not all members of this forum will have a STOC #, and not every owner will be a member of this forum, or have a STOC # from some other source. So lets say there are 10,000 of us that care enough about these bikes to register a STOC. Those that care enough, probably on average have more than one ST (some like Bob buck the trend and I'm surprised his wife puts up with it), some will only have 1 bike that they look after better than their kids. So lets say on average each STOC registered person, has 2 bikes.
I make that a ballpark 20,000 bikes. I've been on this forum around 2 years, and I can recall on one hand the number of threads that resulted in an ECU swap fixing the problem. So lets say that there's 5 ECU swaps every 2 years, my ST1300A2 is now 19 years old, so following the average, lets be charitable and say that's 50 ECU swaps that STOC members are aware of, in 20 years. Note here that my number of bikes is lower than actual sales, and that my number of "known ECU swaps" is probably higher than actual, which means the final number is a gross overestimate of frequency.
I make that 50 swaps from 20k bikes, or 0.25%, or 1 in 400 bikes will at some point in 20 years, need it's ECU swapping. Again, that's a gross over-estimate. I'll suggest half the STOC numbers are 1100 riders, half are 1300, so for either bike, it's closer to 0.125% chance in 20 years. Of course, I bet STOC numbers are heavily weighted towards the 1100, but this is an envelope calculation.
"But wait, ad.hom, 1 in 400 bikes sounds like I should sue Mother Honda!" I hear someone at the back cry... well... some perspective is in order...
Let's say you're 65 years old, a smoker, and live in the US. You have a 1 in 400 chance of dying in the next 10 years from any of: heart disease, stroke, cancer, pneumonia, aids, COPD or any accident like crossing the street. If you never smoked, your chances are 1 in 800. If you're not interested in suing a big tobacco corporation, I probably wouldn't recommend you try suing Honda either. Again, I know it wasn't the point of the thread, but it's worth exploring these things anyway.
1 in 100 die of obesity. 1 in 500 of a food borne illness. 1 in 33 develop skin cancer. 1 in 200 die in a homicide (US data, 2009).
Again, my number was grossly over-estimated.
So, theory and speculation out of the way...
Be very careful of those sites. Assuming they know what they're doing with any ECU, there's a strong chance they'll brick an ECU if they're not familiar with the ST ECU. Most sites like this tend to have done it once before, and they got lucky. With the number of people wanting different fuel maps for supposed throttle issues on STs, companies that will do fuel maps are still pretty rare - and that has nothing to do with the age of the bikes. I honestly wouldn't waste my money unless they were willing to put you in direct contact, on the phone, with someone that has used their services and still rides the ST they modified.
Fun fact too, I was trying to figure out how to tweak the ECU on my Jaguar many moons ago, so I put an industry standard tool into diagnostic mode, seeing if it could just do a raw dump of the CAN traffic for me to analyse later. This was a 2005 car. About 10minutes into my journey, the LCD on my dash lit up "TAMPER DETECTED. SHUTDOWN IN PROGRESS." - and the whole electrical system went dead. At 70mph, I lost power steering, ABS, ignition, radio, everything. If my 2005 car had that, what's the chances of Honda putting tamper detection into ECUs?
Can the ECU be tampered with? Probably. In my line of work I like to think that nothing is impossible. But, everything comes with a cost in some shape. I'm actually interested some day to compare a police ST ECU with a civilian one, mostly for the sake of curiosity - but assuming there's some tamper detection baked in, I'd probably burn through 6 of each type before I knew the differences. I'm not sure as a group, we have 12 spare ECUs for me to play with, just for a curiosity.
Then there comes the supply & demand aspect to it... if we're talking about learning how to fix FI fault codes, and lets imagine I did figure that out. I'm looking at less than 50 sales over 20 years. That makes my unit cost so high that it's just cheaper to pay the price for a new/used functional ECU. It'd also have to take it's own priority in my "pet projects" queue, unless someone is going to pay me enough to figure this out that I can quit the day job.
Even if ECU's turn into unobtainium like the wind deflector kits, it's sad to say, but you're insane if you want to pay me to dig into ECUs rather than just buy another bike.
We have 2 Sts in our family (05 and 03), and the ECM failure rate on those was 100%.
I would negotiate the replacement price into any purchase of an older model.
While your sample size is small, this is a good point:
Use whatever you can to drive down the price. The reason I didn't buy the 1100 was because of the swing arm corrosion known issues - and I live not too far from the sea, so salt water will be in the air.
If you factor it in, and still buy the bike, you're not so worried if you get unlucky.
Ha! I have an exact example of what you're talking about. One of my other bikes, ( I'm down to 4 ) is a Triumph Tiger 1050. That's the orange bike in my Avatar. ( That's Southern California by the way, freakin' awesome roads )They are known for some bikes, depending on which tune is in the ECU, to crack piston ring lands. Why? Nobody is certain but ethanol fuel is one culprit which may or may not have been factored into the factory tune. Point is I wanted to try the Tiger and came across a great deal due to higher miles, I think it was 70k kms. BUT I also knew Jim Hamlin, who is a very respected Triumph mechanic in the US, had the last set of a batch of custom Wiseco pistons in his shop. I factored in the cost of replacing the pistons should there be an issue. The pistons are currently sitting in the basement workshop.
Hmm, most combat veterans will tell you they used some form of this to get through the day. If the bomb, bullet, hand grenade, or in our case ECU, doesn't have your name on, well, you're invincible. And if they do, ain't nothing you can do about it. So, carry on the mission, or go for a ride...it's a Honda, you meet the nicest people riding them. Mechanics are nice people too...Just sayin':biggrin:
I posted this in another thread but after trying 2 used units off Ebay, replacing the sub harness, and sensors, I bought a new $800 unit.
The bike was 14 years old and 88k miles when the ECM went. Thats a little less than a penny a mile.
Its a hell of A Lot easier to replace the ECM than the damn alternator. Just consider it part of ownership and go with it.
Its called potting. The manufacturer pours one of several different epoxy like compounds into the enclosure with the electronics. Some of these protect the circuit board from environmental conditions (moisture, sticky little fingers) and some are to protect a proprietary design. And of course, these substances have lead to the development of depotting compounds (unpotting, anyone?). I joke not. (This is one of those rare examples. Flag it.)
If you look at my signature, you'll see I have over 390,000 miles on 5 different ST1300s. I have yet had an issues with an ECU. However, when I bought the 2010, the ABS computer was not working, but I can only contribute that to the accident it had before I bought it. It only had 1,500 miles on it, at that time.
Welcome to the party Bob, I did account for you specifically in the statistics.
Maybe it's actually more accurate to look at the failure rate per mile ridden, and break those down by initial cause... eg, mouse vs accident. I'll let someone else run those numbers though.
