Smallest USB Port I Could Find
Willsmotorcycle
Ride more...
Makefield Highlands PA
2016 ST1300P
2025 Miles
001084
I am looking for a small USB for the phone I just mounted on top of the dash. I will be installing it on the left side but every time I tried fitting it I opened my garage door so it’s dry fit on the left.
They are all about 5/8” high. the finish matches well and two out of three have LED indicators. I will be hooking it up to the quartet switched. Anyone want to start throwing out some ideas? @STRider I need you. ;)
Just think of where and what you'll have stuff to charge or power.
Where will the cables go? Will they be in the way of anything? Will they interfere with seeing gauges or instruments, or foul the handlebars?
My Powerlet is on the right side just below the fairing pocket, and I usually just run a USB cable up to what I need, tucked into the tankbag which is always present. There are also connectors you can run right through the front or side of a tankbag, easy to do, or find a tankbag with the port already installed.
I have adapters for the Hella / BMW / DIN / John Deere-styled connector outlet, for whatever I might want to use. And the good news is, you don't have to buy Powerlet-branded accessories or connectors.
