Interesting article about tire pressures
the Ferret
Daily rider since May 1965
So-Oh
21 NC750 14 CB1100
007505
How to find the best tire pressure for your motorcycle
not saying it's right, not saying it's wrong, just saying it's interesting
It's a thoughtful and well-written article. The only thing I found "odd" was that the rear tire pressure on my two STs only goes up about 3 or 4 PSI from stone cold to after an hour of highway riding - that's a lot less than the 20% that the write suggests might be encountered. I use OEM recommended cold pressures, and total payload (not counting fuel) when I ride is about 220 pounds.
Michael
Interesting UP. 42 to 50 would be 20%. I was wondering what TPMS users saw on their units wonder why its so much different than CYYJ's
I would think it would have a lot to do with the amount of 'payload' - I'm baby water buffalo size and pack a lot of stuff. :biggrin:
I know the more you load up a trailer, the 'hotter' the tires get - which I believe the rising temps cause the pressures to rise.
Oh thank goodness. I read the article and panicked as I'm in the upper 40's to low 50's. But, then I read Uncle Phil's experience. Since I've retired I can give the baby water buffalo a run for it's money. In other words, I've gained some weight.:biggrin:
Pavement temperature and pressure are related, I monitor TPMS pressures.... 42 going up to 50 isn't unusual when it's hot out.... up your rear to 44 is what I'd do on a heavier ST.... it will keep that down a bit as the tire flex will be less and less heat, a little bit longer tire life too (not a lot). Brand of tire makes a difference too..... Bridgestones have stiff sidewalls, Michelins are soft... up your pressures with the Michelins.
