- Joined
- Sep 26, 2011
- Messages
- 757
- Location
- Springville, Indiana
- Bike
- 2000 ST1100
- 2024 Miles
- 001743
- STOC #
- 8497
I did similar lately also. I have five 8ft sections of florescent bulbs in my garage and replaced two of them with a round LED light with 4 adjustable paddles. Man they are bright! A lot brighter than what I had and so small also. Much better, I agree!
I did similar but instead of swapping out the fixtures I just put in the LED tubes from Costco. It was a quick upgrade by just swapping tubes.
Are these brighter than the reg tubes. I have 4 four tube fixtures. Would like a bit more light with less cost.
I found them to be brighter. They are also a different color temperature than my old bulbs were.
I got mine as a 2 pack at Costco when they were on …
As for the other screw in bulb replacements I have 6 of the metal framed black tri LED panels ones and one of plastic white kind to see if they were ….
Did the same in the garage with just two of the black version. Painted the walls slate gray and replaced the garage door opener bulbs with 100w equiv leds. What a difference!
Philips 40W Equivalent 4 ft. Linear T12 Type A Instant Fit Daylight Deluxe LED Tube Light Bulb (6500K) (1-Pack) 545624 - The Home Depot
Philips InstantFit T12 LED Tubes. Installs easily with no rewiring. The Philips InstantFit T12 LED Tube (16T12/LED/48-865/UF18/G) is the fast, easy way to replace T12 linear fluorescent bulbs on most light fixtures with rapid start magnetic ballasts. It's compatible with 50% more ballasts than...www.homedepot.com
My door openers are touchy with the regular LED bulbs in them.
One won't light the LED bulbs at all and one makes them flash. Voltages on the socket seem to be in the constant 120v range when I checked them with a VOM.
There's also notes on them not to use LED's due to digital interference with the receiver that may make the door work poorly. Your garage door opener may vary
Bummer. Hard to comply with energy savings if that’s the case. So far so good with our 20 year old craftsman lift. It has a motion sensor that we employ when you walk in the dark garage it lights up fine. And all the remotes work no problem.
I have a severe case of garage envy. Some of your garages look amazing; clean, organized, well-layed out. It's really impressive. Mine is a mish mash of ADD disorganization.
