Hello,
I bought a 1998 Honda ST1100 CBS-ABS-TCS, 159000Km, which was a bit unused for a while. The motorcycle starts, the engine works well, the brakes are quite weak, it can be seen that it went to the bolts of the cylinder head protection covers, which cover the protection cover of the timing belt, but I do not have a history of service and requires minimal maintenance to be safe to operate. It had a lot of changes and additions in the electrical installation, which I removed to bring it up to standards. I have a doubt though. One of the former owners made an extension to use both low beam bulbs, although the headlight glass is not identical on both sides. Please, if you can help me with tips, to leave the connector for the short phase. The motorcycle was imported from Germany, it can be seen that it was lying on the left, I assume that the headlight was also damaged and may have been replaced. The engine code is SC26E, so I don't know if it's the EU or UK version and I don't know what type of headlight is fitted. I put a photo with his glass (which is on the motorcycle) and another photo with another type of headlight, which I assume should equip the model that has both bulbs connected on both phases, to see the differences in appearance. What "eye" need to have the low beam bulb connected? Thank you.
