tlub
There is no indication the bike has HISS.
I did test it in right at turn-on. I hooked up the meter, then tuned it on.
I'm looking for bad earths, but haven't really found any except at the fuel pump, where the connector was corroded.
I'm still deep into this. I did confirm that the bk/wh wires at the coils do indeed get 12v when I turn it on. It did sit for a while, and there is evidence of mice. But I don't see any chewed wires. I have the ecu out now (I told you I'm in deep) but without the specialized wire harness, don't know of any tests other than the ground/ 12v test in the manual. I'm trying to figure out a way to make that test without the test harness.
I am thinking that the ecu is not letting the bike start. But whether it's because of a bad signal from some sensor, or the ecu being bad, I really don't know.
Is there a set of tests than can be done, like with some other vehicles, such as lookinf for resistance readings, voltage, etc when one does different things?
