- Joined
- Feb 5, 2005
- Messages
- 8,539
- Age
- 77
- Location
- Kingman, Arizona
- Bike
- 2000 ST1100 ABS TCS
- STOC #
- 004
I've had cars where oil and plugs were no simple task. One had the engine oil filter located on the back side between the crankcase and firewall...couldn't reach it above or with the vehicle jacked up without moving the back side exhaust. (transverse v6 Olds). Several have required oddball, unique plug sockets to access the backside plugs....again, no room between the aft head and firewall. (Chevy transverse V6). Both these required unnecessary cost. I have removed both makers from my 'buy' list.George... When I think of all my colleage at work, who don't even want to take the risk of changing the oil on their motorcycle.
They sometimes wait for a few weeks, for their appointment to the dealer, for simple things.
And you, just like that, with no garage and only a few handtools, at 75... you just changed your rear shock.
Wow ! Truly impressive. Congrats, man.
It's like the manufacturers do it on purpose .I've had cars where oil and plugs were no simple task. One had the engine oil filter located on the back side between the crankcase and firewall...couldn't reach it above or with the vehicle jacked up without moving the back side exhaust. (transverse v6 Olds). Several have required oddball, unique plug sockets to access the backside plugs....again, no room between the aft head and firewall. (Chevy transverse V6). Both these required unnecessary cost. I have removed both makers from my 'buy' list.
Ever do a timing belt and spark plug change on a Toyota Sienna? Toyota, one of the vaunted great car makers? To access the rear plugs on the transverse V6, you much remove the entire cowl, windshield wiper assembly, and the intake manifold. Roughly 3 hrs to get to those back three plugs. The rest of the timing belt change is relatively straightforward, well, unless you don't have an impact wrench capable of 1 MILLION ft/lbs to remove the damper bolt. All the manufacturers have total pigs, not just GM. Anything with a transverse V engine is gonna be a "female dog"
RT
I had a second gen, 2006. There is no way, no way of getting to those back plugs without tearing it apart. It wasn't difficult, just tedious. Plugs had a bit of oil on them, as the valve cover seals were failing. The valve cover seals on that engine are RIVETED in. Easier to replace the entire cover. I ended up selling it and getting a Sub.I never did a timing belt on our Sienna (1998 1st gen) but I was able to change the plugs without pulling the cowling, wiper assembly or intake manifold. Had to work by feel and other than accidentally removing one of the new plugs I'd just installed, thinking I was on the next one, it wasn't too difficult. I was fixing to do the timing belt too, when I received an add from the local dealer offering a timing belt replacement special for $175, parts and labor. Dropped the car off later that day!
