- Joined
- May 27, 2021
- Messages
- 1,162
- Age
- 64
- Location
- Coquitlam British Columbia Canada
- Bike
- 2009 ST1300
Welcome from Vancouver
Hi Jamie:
I'm happy to hear that you are enjoying the motorcycle. For the benefit of other forum members, that is the ST 1300 that previously belonged to me, I sold it to Jamie about a week ago.
Now, about that bolt: You DON'T want the 'correct screw for the hole' that is specified in the parts catalog, because the threads inside the hole that the bolt fits into are damaged. The bolt is a shoulder bolt, meaning it has a shoulder about 3mm high that prevents the head of the bolt from being tightened right up against the threaded hole. This is important, because if the bolt was tightened up against the plastic part, the plastic part would crack.
Your post reminded me that what I should have done - but didn't get around to - was identifying the part number of a similar Honda shoulder bolt with a larger thread diameter, getting one of those larger bolts, then tapping out the hole to accept the thread of the larger bolt. I apologize for failing to fix this before selling you the motorcycle.
Perhaps some oracle of ST 1300 knowledge (Hi Larry, are you around?) could let you know the part number of the next larger size shoulder bolt used elsewhere on a ST 1300, and maybe even the thread diameter and thread pitch. With that knowledge, you could then get the appropriate bolt and also a tap to match. Use the tap to chase in new threads in the hole on the frame, then install the larger bolt. There is a ST 1300 Tupperware Worksheet available here in the forum, that might also be of use.
Looking at this image, the bolt that is missing (the one that goes in the hole shown in your photo above) is a 5 mm shoulder bolt that fits into position 2 on the part labelled "Right Side Cover". I believe that if you obtain a 6 mm shoulder bolt such as the one that fits into position 3 on the same Right Side Cover, and then tap the hole at position 3 to accept the threads of the 6 mm bolt, that should solve your problem.
As for where to get parts, for little stuff like this I just go to a local Honda dealer. Some Honda parts are common to many different bike models and for that reason they will often be in stock. A shoulder bolt like this is probably unique to ST 1300 and/or Gold Wing models and will likely need to be ordered. Even if your local Honda dealer doesn't know what a ST 1300 is, they can still order the part for you.
Let me know how much the bolt & tap cost and I will reimburse you for your expenses - I should have fixed that problem before I sold you the bike, but I simply forgot to do so.
Michael
I thought Jamie is in Canada. Why would he ship parts to US?You're paying way more than you have to. Shipping is free to a US destination after ordering about $80 worth.
He means shipped from a US vendor to a US address, where he would go and pick them up and transport them across the border himself.I thought Jamie is in Canada. Why would he ship parts to US?
And while I've got your attention - you've likely figured it out by now that there are lots Ontario members on here. We "ride to eat" now and then, we play riding games (Tag & A-Z City game), and once a year we have a weekend away (Onstoc). This year its in Sept in Calabogie. Many of us venture off to ride in the US by attending a forum STOC event like OHioStoc or just heading out. You're very welcome to join any game or organized event. Just jump in - no invites needed. The info for all of those things is on the forum somewhere. If you can't find and want links to read up, let me know. Happy to help
CYYJ. Honourable of you to re-imberse? for tap etc.Bravo.
Also, I may live in the Hammer, but I was born and raised on the East Coast (NS/NB). One of my bucket list items for the bike is to take a trip back there. Most likely not this year, but hopefully next.
I asked someone who works in the customs world. He is not a broker per se, but is in the business.
Using taps is very easy. For a new hole, you need the proper size drill, but for what you are doing, you will probably be able to do it by simply chasing the hole with a tap. Buy a tap wrench - a T-handled type that will give you control - add a couple of drops of oil to the tip and carefully screw it into the hole. Be very careful, taps are hardened steel and brittle. If you break it off flush, removing the stub can be very difficult. Turn it until you feel resistance, back it off half a turn to cut the shavings free, then resume screwing it into the hole. My method is to screw it in one turn, feel resistance, back it off half, in one turn, etc. Experience and a few broken taps will teach you how much force is needed to snap the tap and cause tears to flow.I'll need to watch some video's on the taps and how to use them.
You definitely have my attention! I am very interested in meeting others...
Where do you fellow Canuks source your parts from?
Fort Nine is located in Montreal. Anything that I have ever ordered from them was free shipping because it is local.I sometime order stuff from FortNine , located in the Toronto area.
