This used 4 x 8 utility trailer weighs 460 lbs ( I had to take it to a public scale for a weight ticket in order to tag it ) and the tongue weight is much too light. It's a boat trailer converted to a cargo deck utility trailer. I am retiring at the end of the year and I bought the trailer with the idea of doing some traveling with my wife and bringing a bike along. She is just not up to traveling long distances on the bike anymore and if we do this together the trailer is necessary. Unladen the tongue weight (TW) is less than 4% although when I towed it the 20 miles home from the shop that built it towed just fine. Scary though when I determined the tongue weight was about 16 lbs! With the NC700X tied down on it the TW is 60 lbs, 6%, and with the RT on it the TW is 8%. I didn't measure the TW with the Goldwing as I saw the pattern developing. I want the TW in the recommended 10-15% of loaded trailer weight.
I thought about taking it back to the welder that built it and have him move the axle back some distance but there are steel angle cross members welded as upside down "L" shapes that complicate just welding new spring hangers to the chassis rails. I messed around with jack stands at different distances from where the axle is now and to get a minimum 9 - 10% TW unladen the axle has to move 6" back or exactly where the cross members interfere with the up and down travel needed for the leaf springs. I read about a similar situation and that owner mounted a couple of ammo cans on either side of the tongue member. He placed sand and scrap metal into the containers and gets the tongue weight to minimum 10%. I gathered 52 lbs of stuff and placed it on the tongue member at the front of the cargo deck and this increased the TW to 10% unladen. I'd like to do this and the .50 caliber ammo cans have a capacity of 34 lbs. I like the idea that I could adjust the tongue weight to whatever bike was loaded on the trailer.
So how to mount the ammo cans or some other way to hold weight? Have the welder fab up some sort of carriers or use 4 bolts in a manner like the trailer jack is mounted? I could drill holes in the cans DIY for the bolts and clamp them to the tongue member. What other ideas come to mind to provide a way to secure an adjustable 40 - 60 lbs of weight just in front of the cargo deck?
