I remember a project in Popular Electronics magazine to build a dwell extender, that would electronically reclose the points faster than they would actually close, for greater coil saturation at high RPMs.
Oh hell yes, if you didn't carry a spare in the glove box, yours would fail the next dayAnyone remember the fusible link on the firewall of 60's and 70's mopars?
Yes. Not good when going uphill in a rainstorm.Remember when you had to let up on the gas to make your vacuum operated wipers work?
WOW! I thought they all folded up. I used to love going to Gibsons and the Motts 5&10. Well I'm glad that there are still a few Gibsons Stores out there.
I grew up in Uvalde and there used to be one on Main street.WOW! I thought they all folded up. I used to love going to Gibsons and the Motts 5&10. Well I'm glad that there are still a few Gibsons Stores out there.
Or the windshield washer pump that ran off the air from theRemember the gas heaters in a VW beetle? Ran on gasoline.
My old 57 Mercedes 190 had a rubber bulb mounted on the floor that you stepped on and squished to make the windshield washers squirt. I used to turn the squirt nozzles around on the hood so I could squirt kids crossing the street at the crosswalk when I was in high school.Or the windshield washer pump that ran off the air from thespare tire.
When I was a mechanic back in the 1970's, when the parts guy was out to lunch, I would take all the condensers out of the parts box and charge them up off an old ignition tester I had in the shop and place them back carefully back into the parts box. I waited for the parts person to return and then would ask him for that particular condenser. It was great fun to listen to the sounds similar to a bug zapper along with the yell when he reached into the box to retrieve a condenser.Did anybody else learn to hate condensers as much as I did? However, while living in Spain in the 80"s, I made a good bit of pocket change from people who tuned up a barely running car with rotor cap, button points and plugs. Then car would have same problem a few days later. I would replace condenser, file points, reset dwell, charge $10.00. took about an hour including buying parts.
Years ago, a mechanic I knew tried to hand me a condenser. I told him to touch the wire to the can first.When I was a mechanic back in the 1970's, when the parts guy was out to lunch, I would take all the condensers out of the parts box and charge them up off an old ignition tester I had in the shop and place them back carefully back into the parts box. I waited for the parts person to return and then would ask him for that particular condenser. It was great fun to listen to the sounds similar to a bug zapper along with the yell when he reached into the box to retrieve a condenser.
I've got a 389 with the original distributor; stock base engine, made a million of them, got it at 68,900 now [eighteen years later] 71,100[?] low horespower; 254 [rated] 2 bbl single exhaust, but still 10.25:1 and 425 lb/ft @ 2,400 or 2,800 [can't remember] I've never [even] used a dwell meter [which I know is the correct way to set points], I think they were expensive back [close to fifty years ago] when and I just got used to setting them up with a feeler gauge, then plus or minus a bit based on ping.
I was surprised a couple years ago to be able to get replacement points and condenser on Rockauto, but after I changed the plugs / wires / cap it ran perfect so they're still in the box.
The transmission is an ST400 with the switch pitch converter [one of the last before the turbo 400]
I would like to put a dwell meter on it before and after replacing the points; what's the old adage, if it works...
