My new car tire won’t fit!☹️
I am requesting some help from experienced darksiders..
I just bought a Falken 205/50 R17 to dark side my 2006 ST. It won’t fit. My understanding from reading other postings that a 205 CT should fit there. My measurements show it is about 3” too wide. Shouldn’t a 205 be the same width for any other 205 tire?
Willsmotorcycle
Ride more...
Makefield Highlands PA
2016 ST1300P
003726
For me to put mine on I had to let the air out and apply lubricant as I caressed (wiggle, push, wiggle, push) it in... It would not fit with air in it.
Obo
East Coast Canada
'03 ST1300A
You needed a 205/50R17 for starters. A 55 is wider. *edit, I see from the photo is says 50
Even with a 205/50R17 some fit fine and some require grinding the swingarm.
I don't recall the ze950 being on the list. I know some here used the Ziex ZE-512, but in the 205/50R17 size.
Thank you for your reply. The width of 205 won’t clear the swingarm without air and mounted on the rim.
Obo
East Coast Canada
'03 ST1300A
@Willsmotorcycle you're also using a different tire (BFG vs Falken)
BFG needs no grinding. Same size Hankook Ventus v12 & General Gmax as03 both need grinding. Same size stamped on the tire. The profile often makes the difference.
Minnesota
2012 ST 1300
007798
8560
Yes it will.
Get some gallon milk jugs and cut then into 6x6 flat square peices. Put them between the tire and the hub as you slide it in and it will make them slide by easier. Once the tire is in air it up. Car tires are more "squared off" or "rounded" at the shoulders. The squarish ones rub the swingarm and the rounder ones don't. The squarish ones also make riding the bike harder and are the source of many of the complaints about the handling of the CT. Before buying any CT look at the profiles. The more it resembles a mc Tire the better its going to work all around.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
After mounting the tire before airing it up I use silicone spray on the tire and swing arm which make it go right between the swing arm. Air it up and ride. You do need to look for the roundest profile on the tread of the tire as the square ones don't handle good.
Richmond, VA
'01 & '96 ST1100s
9007
I would think the tire would be a bit easier to get in if you don't seat the beads until it's in place.
Texas Panhandle
And then there's me. After about 250,000 car tire miles, I much prefer the square/flat profile tires running a touch under 30PSI.
Fort Worth
You can't compare the apparent width of the unmounted car tire.
I did that with my first CT, and was convinced it would never mount nor fit the swingarm.
But it did both.
And performed very well.
Mount it, seat the beads, then remove all the air AND valve core, and use the lubed milk carton trick, slowly and back/forth.
