Speaking of oil... anyone remember where it goes?
Bobcaygeon, ON, Canada
2008 ST1300a
Isn't it 3.9 litres with a filter change.
How much have you put in?
If it's not showing it needs more, no?
Yes, I was wanting to double check the level before adding the last little bit - worried more about overfilling. Why I am concerned is there is nothing showing with 3.7l in there, shouldn't something show in the indicator window? Mine looks completely empty.
Iowa, USA
'05 ST1300
The owner's manual has instructions to start the engine for a few minutes then shut off the engine and check the oil level glass. I can post the instructions if needed. It may be that the fresh oil didn't have time to drain down into the oil pan after you poured it in.
EDIT: Was the bike on the side or center stand? This might affect the reading, too.
