I have an 05 ST1300 with 93,000 miles on it. I just put in a new clutch pack (OEM), new master slave cylinder and have bled the heck out of the clutch fluid. I put in Mobile 1 10W40 motorcycle oil and used Prestone DOT 4 clutch fluid, cleaned and lubed the shift linkage making sure there are no obstructions or play in the linkage. Before I replaced the previously stated parts, I did not have the issue and difficulty of shifting into neutral. I have already searched previous threads on the forums, and they have recommended bleeding, clean and lube shift linkage. I am wondering if there are any other recommendations? Thank you
