Hi, first post here.
I recently bought a 2001 ST1100 and have been riding it around town but since then the throttle started not snapping back. I'm a green mechanic, but the handlebar throttle assembly part is easy enough to get to. Cables aren't frayed, sprayed some WD40 and then some cable and chain lube down both cables which seemed to have fixed the problem.
After closing up the assembly and leaving it for a bit to saturate and marinade, the throttle no longer snaps back again. It rides fine I just have to "manually" move the throttle to the closed position.
Next step is to look at the carburetor/engine end and I think the throttle body is to the back on the left side, correct? What's the easiest way to get to it? I'm hoping this doesn't require removing the gas tank.
Thank you, any insights would be helpful.
