- Joined
- Oct 26, 2020
- Messages
- 2,072
- Location
- Makefield Highlands PA
- Bike
- 2016 ST1300P
- 2025 Miles
- 001084
I have a set of https://a.co/d/7vfWnoT 4" hi and lo beam:
I really like them and ran them for 25k miles or so. I was looking for a bit more punch and went with some Hella. I didn't really love the round on the parade bracket, I always thought the ST looks good with round lights under the mirror. First problem is the configuration/ orientation of the lights, they are designed to mounted with the bracket on the bottom. I opened one up and saw that flipping the reflector was not a problem if I cut some metal for the power cables.
I took out the grinder and removed about 1/2" from the "front" of the plate so the wire can run through.
Put them back together and it all works as before, now the tricky part, I have the Parade bars coming out of the mirror covers and they limit my choices.
I know @Obo and @dduelin and others had a clever way to mount lights under the mirror using the mirror arm hole, my bracket bolt is blocking the straight thru. I've mocked up a little L bracket to see what I'm working with, it needs to be "shaped" to stay close to the fairing, not an easy task,
anyone have any suggestions to get this light down there? Thank you in advance.
