Article [13] ST1300 - Maintenance - Front & Rear Wheel Install and Front Axle Animation
That required the stopper bolt to be secured before the axle. Otherwise it could lock in an angular / alignment difference between the bracket and the bolt,
During rear wheel securing process, there are no opposing forces that act upon the stopper bolt and the rear caliper bracket (that may perhaps cause twisting of caliper bracket and perhaps some caliper misalignment).
The caliper bracket alignment features are the flat surfaces resting against the inside of swingarm and wheel hub - that is the design position. How is securing the axle nut while holding the other end going to generate any force in caliper bracket against the stopper bolt, and in turn create a torsion momentum in the caliper bracket??
It appears to me that some of you just keep questioning the instructions and measurements, and have stopped trying to figure out what has actually changed, or is actually causing the issues.
Your looking for the problems instead of the solutions.
Find the cause of the problem instead of throwing solutions at the problem etc.
Perhaps you should start searching for the cause, instead of questioning the cause.
People keep talking about the "set up", which side the spacers go, the gap, the way the forks move, etc.
We know all these things already, but what your searching for is why it is different for some reason.
Many things can cause these issues...
Were the bearings seated at the correct depth, or married too tightly against the inner wheel race (this will change a measurement)?
Are the dust seals over the bearings flattening out? (this will change a measurement)
Is the torque wrench used to tighten the axle correct, or has it been over tightening the axle, moving the bearing in too deep?
Is the end of the axle peened out and not sliding into the fork lower smoothly, pulling things out of measurement?
Is the hole in the end of the axle have a raised burr digging into the fork lower, dragging and pulling things out?
Are the wheel bearings OEM Honda, or have they ever been replaced with aftermarket cheaper bearings that may have different measurements?
Instead of fighting this with logic, trying to prove or disprove why it does not make any sense because the book measurements are such, take a step back, take a deep breath, and start really looking at things in detail, I'm sure you'll see something.
It's just a general discussion Larry - arising from the fact that I seem have more available clearance than Andrew. I was suggesting ways in which it could possibly happen - but the bottom line is that nothing you can do will affect the total amount of clearance available. Only whether the disc is too close to one side or the other. There is a gap the disk has to pass through it with a certain clearance on each side.
The total gap that I have is about 7.6mm. 5mm of which is occupied by the brake disc. The disc sits quite centrally in that gap. But I don't remember the gap beign that large with my first 1300.
@draser
The stopper bolt has to be secured first so that the threads pull the head squarely against the boss on the swinging arm - and so that the peg square to the elongated hole int he caliper bracket.
If the axle bolt is tightened first, the stopper bolt can be sitting too low - so it has room to move/drop on untightened threads. Or- when the axle bolt is tightened, the caliper bracket tends to move round clockwise - which could pull an unsecured stopper bolt.
If the bolt isn't in place. a similar thing can happen. The hole isn't properly aligned, but the shaft of the bolt will go into the hole at a slight angle. It can be tightened - but it won't necessarily be tightening the flange of the bolt against the face of the boss on the swing arm. It will tighten against the threads when the bolt cannot straighten itself out any more.
So making sure that the stopper bolt is properly secured first ensure that the above cannot happen.
Like stated in the post... the axle is held stationary and the nut is tightened.
Not sure how... since it's snugged in its threads but not torqued to spec. From what I remember... it's a fine thread with minimal thread play, and when fully inserted until it stops (normal assembly practice) it'll present a parallel surface to the hole in the bracket.
I can see an "angle" happening if bolt is inserted afterwards, like you're stating, but even then if the bolt can be hand started and screwed in all the way w-out effort I don't see a problem.
I saw the manual... I guess it's written to prevent hand starting the bolt (2-3 threads in) then torquing the axle nut, then snugging up the stop bolt and then torquing... which doesn't make much sense... but it's worst case scenario.
To take this further, the issues with rear caliper bracket wear, or uneven wear I should say, simply comes from caliper not exercising equal forces on both sides, hence one pad works harder than the other... and guess what, that does create torque which moves one pad more than the other and pushes unequally against the locator clip in the bracket... and then we see the triangular wear in the recess where this clip resides. And why is the rear caliper going that... well, as seen numerous times on cars/motorcycles, where one pad is thinner than the other, the lack of maintenance of the caliper sliding pin(s) and pistons/seals determine the "floating" caliper to not float/self adjust anymore.
Also, caliper design robustness is responsible for some of that, they should have used the 2-pin locator system for the pads just like the fronts are, but... since the rear braking is only say.. 20% of the total braking force, it's passable.
...... take a step back, take a deep breath, and start really looking at things in detail, I'm sure you'll see something.
I have, every time that I put the wheel on and I have never found anything that appears wrong.
I can confirm that the wheel bearings are Honda OEM bearings, so OEM in fact that they are still the original ones installed by Honda at the factory. I don't intend to remove them solely to investigate this so determining whether or not Honda installed them correctly will wait until they need to be replaced. As stated earlier, I get the same result with my spare wheel so both wheels would have to have their bearings installed in the same defective manner to the same degree, which would be quite the coincidence.
Beyond that none, not one, of the other items that you have suggested as a potential cause are present unfortunately. I wish one of them were so I would know the cause, so if you have any other hunches I'm happy to check them.
Unlike the left-hand SMC side where the position of the caliper bracket and brake disc can be changed relative to each other, this is not the case with the right-hand side. The right-hand side caliper bracket and brake disc are clamped in a fixed position relative to each other, and this can't be altered. Many of the items that can influence this clearance Honda does not provide dimensions for.
I am wondering about this. By design, dust seals are passive components, and I don’t see how they could influence the position of the front wheel on the axle. The collars are designed with 10 mm shoulders that sit directly on the bearings' inner races, ensuring a metal-to-metal contact. The dust seals are constrained within this space but don’t play any role in the torque sequence or alignment process.
Am I missing something?
1728640143072.pngI think the issue arises when the collars, sides, orientations are mixed up. To many of us there is ony one way. To someone who doesn't know/doesn't check/makes a mistake - there are 8 different ways that you can attempt to fit those collars. Only one is correct.
The issue that Larry describes can arise with the collar that is intended to fit on the left hand side. This has a 10mm shoulder and a 4.1mm shoulder. The 10mm shoulder always fits into the bearing. But if that is put in the wrong way round on the left or on the right hand side, then tightening the axle will clamp that flange directly onto the bearing seal, squashing it by 60%. Once squashed it doesn't bounce back - so subsequent fitting of the correct colalr is going to be hampered by a severly flattedned seal. Which I think is what Larry was suggesting might be the cause of loss of clearance.
And lets face it - when you look at that 4.1mm side (see pic) - somehow, although it is correct, it looks to be really odd. It looks too small - because when fitted the axle shoulder buts up against it and makes it look longer than 4mm. So I guess people think it should be turned round the other way.
And if anyone is capable of making that mistake, they are also capable of trying to fit the same collar onto the right hand side.
In fact all of this discussion has come about because I commented that I had "oodles of clearance" on both sides of the disk. Mine is roughly even at 1.33 and 1.24mm. Significantly more than 0.7mm. Nearly twice. I don't know how that compares to the other bike - I just know that the other is within the 0.7mm spec. The 'problem' may come down to my use of the word 'Oodles'.
First is it possible confusion is arising from John Heath saying he has 1.33mm and 1.24mm ON THE LEFT SMC SIDE and Andrew saying his RIGHT SIDE is only .7mm?
The left side (SMC) can be changed by moving the fork on the axle but the right side (non SMC) is fixed and ends up where the manufactured parts fasten together. Those part thickness's will vary with manufacturing part tolerances resulting in clearance variations so Honda sets .7mm as the minimum clearance allowed.
@Andrew Shadow my RIGHT SIDE NON SMC SIDE has a measurement of .047" or 1.19mm. That is the thickness of feeler gauges that I can lightly force in under at the closest point of the caliper bracket to the disc. It does "give" a bit when inserted so true clearance would be a bit less maybe .040" or 1mm. I can't "feel" the true clearance so a light forced measurement was done. This clearance IS AFFECTED by the thickness of the brake disc. Mine is near new (just replaced) at 4.95mm thick. As the disc wears clearance will increase. I was serious earlier when I said my 4.1mm worn disc would give you more clearance.
This is one of those cases of where if it works the day you got the bike it should only get better as it wears down. I don't think it is even something a person would ever check (unless you crunch the bike) unless he is making parts changes to the brake system. I think half the Honda spec of .7mm minimum would still work as clearance is clearance and these parts don't move in use.
Short version, my bracket to disc clearance on the right side is 1mm.
I check it every time that I install the front wheel as indicated in the service manual.
I didn't measure my discs. They are still the original ones and unless they were manufactured to thick they shouldn't be an influence.
I am measuring in inches because I don't have metric feeler gauges. 0.7mm is 0.28". On the right-hand side between the brake disc outer face and the brake the largest clearance that I have is 0.030". At one spot particular spot only I have about 0.025"- hard to measure. I do have clearance however and there is nothing touching anywhere and I have no brake performance problems of any kind and there is no symptoms of any negative impact on the brake performance so for now I use it as it is. Maybe when the time comes to replace the wheel bearing I will find something. I just have always wondered why it is so tight on the one side. There is plenty of room, oodles in fact, for the disc to be moved way over to the left and be much more centered in the caliper. I no longer know anyone with an ST1300 that I can use to compare parts with to see if something on mine is different that would shift everything to the right so I am left curious about it.
I'll get out and measure my right hand side. I hadn't considered that that may be the difference ! Is yours a 2009 purchased ST1300 ?
Ok - that is broadly similar. I just put 4 gauges together, trapped them in the holder and they slid through the gap with a slight drag - 0.30, 0.28, 0.33, 0.38 = 1.29mm
One was easier than the other three. And by far the easiest to measure was the inner side of the disk viewed from the other side - so eg the right hand caliper, inner disk surface, viewed from the left hand side through the spokes. You can get a good idea of the angle to use and pushing it slightly up towards the edge of the brake disk, you can see the gauges emerge at the other side. (Although it only has to go through the start of the slot - its good to know it is clear all the way through.). On the outer side of the disk, the view is obscured.
It is a 2009 model year that I purchased at the end of December of 2011.
The serial number label affixed to the head-stock states 12/08. I have always assumed that this meant that it was manufactured in December of 2008.
We don't have anything like that on the headstock - just the VIN. I only know the date of production because of mine because I was buying a brand new bike in Dec 2013. It was discounted. I wanted to know that it hadn't been sat around in the showroom for 4 years. Or salvaged from the aftermath of the Tsunami. Then he started giving incorrect facts about it to convince me. So I started backing off from the sale. He got onto Honda and they sent me a copy of the production slip.
I have read al postings and the documents. Their is no mention about the mudguard. Installing before or after the front wheel procedure? Why? It is bolted to the forks. Can this affect the allignment?
Logically, it ought to be secured AFTER the front wheel has been bounced so that things are free to move. I usually take my wheels off when the bike is on the ground, not on the ramp - so it is easy to bounce the wheels before installing the guard. I'm inclined to think that is what I do, because I have considered the sequence before - but doing it from habit I cannot really say that is what I do every time. Probably.
I seem to recall the service manual saying to install the wheel first, but I don't have the manual at hand. When I replaced my front mudguard earlier this year, along with a fork oil & spring change, I remember the mudguard being a very tight fit and having to work to avoid damaging the new paint during install. I suspect that after it has been mounted awhile it will flex and conform to the forks, but I'm no polymer engineer.
Thanks for the reply. I have tried it yesterday. Allignment with the mudguard in place but not yet mounted tight and without. That is a real difference. It is the same with the brake hoses bridge on top of the mudguard. It wil cause the forks to move outwards.
I believe the best is to install the wheel with the procedure is written here.
But with everything loose.
Brakes and hoses and no mudguard.
After this you will notice that the fitting of the mudguard is much tighter.
Painting the forks will also make the mudguard fit tighter. As will build up of rust on the rectangular captive thread on the inside of the mudguard. But I'm in the UK: rust prevention and reducing the build up of corrosion in the ST1300's hidden places is a constant battle.
General rule - loosely assemble things first and then tighten when they are in place.
Except .... (I can hear Larry missing his fingering for the B7 flattened 9th as he read that last statement ) ... Except for the rear caliper stopper bolt. Get that in and torqued up first.
Glad it is sorted @PanRider1300
I may have misunderstood but unless some other work is being done removing the front mud-guard (fender) is not required in order to remove or install the front wheel.
What is than the purpose of this whole allignment procedure if the forks are tight due to the mudguard and the brake lines? They can not move when the rest is tighten.
Beside this all, i can not believe that a garage wil do this.
I think that this procedure is good but only if the forks are free in movement.
