I would offer my two bits, but the one I use isn't available. Does it work? Yes it does what I need. Is it easy to use? Once set up it is hands-free. I have the sensors on rubber stems but plan on putting in metal ones at the next tire change.
Setup was a bit confusing since it only has two buttons and aren't well labeled. If you've ever used or changed the time on an old watch, that's about how it is with this unit. But once you get the limits set it's no-brain. It is simplistic in that it goes off if the pressure drops 20% or drops rapidly instead of a set number, but for this application it works fine for me. However, I do prefer to set my own alarm limit.
I've shared a Brand Store on Amazon with you. https://www.amazon.com/stores/STEEL...ag=mshop-android-att-ampd-all-phone-pre-us-20
