Old Enough To Remember?
... way into the 80ies a/c in cars were rare and mainly found in luxurious vehicles over here...
Thus a VW Beetle with such, pretty rare...
Did it work as well as their 'heater'?
Actually just lack of care/maintenance... :unsure:
The heater channel hoses inside the A-column were paper lined... dew from the windscreen could run down there through the defroster nozzles in the left & right lower corners, causing the paper to de-laminate and collapse, thus clog the elbow in the air-duct running inside the sill behind the front wheels (ergo foot-well: full blast, windscreen: nearly zero air flow)...
On my '71 (already equipped with the "ventilation-croissants" behind the rear side windows) I simply thoroughly cleaned out all the offending paper bits (shop-vac and a piece of welding-wire with a hook bend at the tip to break/dislodge stubborn pieces), installed new hoses inside the A-columns and voilà: never needed so scrape ice again, ever... :cool:
Max heat with full air-flow on the windscreen, right from the second that engine fired, whilst liquid cooled require a few minutes to warm up the water-jacket; even worse on 'modern' cars which prioritize fast raise of engine temp over cabin heat due emission regs...
