I have an 06 ST1300 with about 44,000 miles on it and lately it seems to not shift smoothly, particularly from 1-2 and 2-1. If I accelerate slowly and shift slowly its smooth as butter, but if I shift normal it clunks into gear. I am getting older so not sure if its me or something with the bike. I only use Honda GN4 10w40 oil. I have replaced and bled the clutch fluid and checked the linkage. I have to be almost to a stop before I can downshift to 1st. Any suggestions.
Hi
@Beajae:
While all of the comments above are interesting, I would start with the clutch.
Honda engines and transmissions are renowned for their durability, and I am sure that your ST1300 is no different from the others. Your mileage at 44,000 (about 71,000 km) is not particularly high for an ST - lots of folks have literally 4x or even 5x that many miles with no troubles in the engine or transmission. Frankly, I would be surprised if the problem has anything to do with engine oil or even the engine at all.
Most shifting problems -
especially with elderly bikes like yours (I mean old in years, not miles), are caused by the clutch dragging (i.e., failing to
fully disengage when you pull the lever in) and that almost always winds up being related to the clutch hydraulic system. The most common culprit is the clutch slave cylinder (aka the
CSC), which is mounted on the rear side of the engine-transmission assembly, up above the centre-stand pivot point.
I had a 2007 ST1300 that I bought in 2015 with around 73,000 km on it, and all was well for around 2-3 years, but then I started experiencing hard shifting - just like you. I quickly found that the clutch is NOT adjustable, and so I eventually zeroed-in on the clutch slave cylinder as the problem. The leak is likely internal, so it won't drop any fluid on the ground - at least for a good while - and even then, it won't be much.
The other potential problem area is the little linkage between the shifter pedal and the shifter shaft under the engine. This linkage can become clogged with road debris, and this can make shifting difficult. To fix that issue, just remove the linkage (a 15-minute task) and clean and re-lube it.
Just be sure to mark the position of the shifter link on the shift-shaft that sticks out of the back ot the engine so that you can get it back onto the shaft in the correct position for the shift pedal to be in the right spot.
Now - I will say that the clutch
master cylinder (the thingy on the LH handlebar) could also be the problem - but history has not shown a lot of master cylinder problems, so I would start with the shift linkage and then move to the slave as the likely problem areas.
If it does turn out to be the master, fixing it is easy and cheap, and the only caution is
DO NOT spill brake fluid on the gas tank as it will take paint off faster than a bride's nighty on wedding day.
Some years ago, I wrote an article on how to remove and replace the clutch slave cylinder, complete with a list of tools and equipment you will need. I recommend that you go there and have a good read - and then order a new CSC (likely around $100) and do the job. It isn't particularly difficult, but access isn't wonderful - so get ready to spend some time lying on your back half under the bike. It is a 2-3 hour job and not too onerous.
Here is the linky:
https://www.st-owners.com/forums/threads/st1300-clutch-slave-cylinder-replacement.155031/
Since then, a whole bunch (like maybe 50-60) people on this forum have changed their slave cylinders and found that it solved their problems. The point is that your bike is now nearly 20 years old, and that seems to be about the average life of a clutch slave cylinder. The CSCs that people have taken out of their 2003-2010 ST1300s all look really bad with lots of corrosion and debris inside the cylinder, so it is likely your turn for this problem to pop up.
Not to worry though. As I mentioned, the job isn't very difficult, and it will save you a bagload of cash as the Honda Manual's solution to this issue begins with the following steps:
1) Drain clutch hydraulic system
[this step will take about 5-10 minutes]
2) Remove engine from motorcycle
[this step will take many hours and cost A LOT of money at a dealership]
3) Remove/replace clutch slave cylinder
[this step will take about 5 minutes once the engine is out of the bike]
4) Reinstall engine in motorcycle
[once again - this is very big job and will cost a ton o'dough]
5) Refill and bleed clutch hydraulic system
[another 25-20 minute job]
So - if you can skip over steps 2) and 4) this job is not too bad and will take 2-3 hours and cost very little. I was quoted more than $1500 at my local dealer and then did the job myself for less than $100 CDN.
A couple of key points - I
DO NOT recommend trying to rebuild the CSC. For the cost of a new one, and the level of effort required to replace it, the savings are not worth taking a risk of getting a bum rebuild. Besides, most of the CSCs that have been removed are an absolute mess and likely wouldn't be rebuildable anyway.
When I did my CSC in about 2018 or so, the rebuild kit was about 80% of the cost of a brand new CSC - so the savings of trying to rebuild it were around the price of a couple of Happy Meals.
Cheers and keep us posted,
Pete
