Thanks
@leondante . All good points. Most are covered in the "Avoiding the pitfalls" article.
I'm surprised about the pool of water, as generally any water ingress is absorbed by the brake fluid. After two years is considered to be 'too wet'. Its moisture content reduces the boiling point of the combined fluid and water and it becomes less effective and potentially dangerous as the fluid can boil. When brakes are released, the expanding gas (steam) ejects more fluid into the reservoir than normal, which leaves a mixture of fluid and gas in the lines. With less fluid in the lines, the cooling gas is now compressible. No brakes.
Some time after the two year period, the wet mixture starts to form a crystallised sludge which can clog up behind the pistons and seals and block the linkage ports (between cylinders)
To avoid this I suggested sluicing the fluid in the pistons. ie pumping the pistons out as far as is safe, and then pushing it out by opening a bleed valve and pushing the piston back in.u When two cylinders are connected, push one in, and then close the valve and push the other in allowing the first to be pushed out. Finish with the one furthest away from the bleed valve being in, and eject the fluid from the one closest to the bleed valve. Repeat.
One problem is that on some models, you have to separate the two caliper halves to remove the pistons and those three bolts need to be replaced with new. The newer front calipers from 2008 are a different single casting design
I've never taken out my pistons (except by accident !) as part of regular service, but I do change fluid and sluice old fluid out in the manner I described, every 18 months or max 2 years. I use the half used fluid from the bottle I filled up with 18 months earlier to flush out all of the old fluid and sluice the bores. The fluid from the bottle will have absorbed moisture over that time, but its the same stuff that went in 18 months ago is sludge free and probably not as wet as the fluid in the lines. Then I use the brand new stuff to flush out the 'cleaning agent'.
A couple of years ago, I noticed one of my pistons was pitted, so I took the opportunity to investigate. The bike was about 10 years old and had about 60,000 mile on the clock. Ridden in all weathers (there isn't any other sort in the UK). I Removed the caliper from the hydraulics and bought brand new seals and two pistons. (It turned out that another piston was also pitted). The seals that I winkled out of their grooves looked pristine and there was no sludge or grunge behind where the seals had been. I was both surprised and pleased - it seems that my procedures for replacing fluid work pretty well at keeping the system sludge free.
Maybe just fresh fluid every two years is enough, but in my head there are 'brackish' spots- fluid that doesn't move when it is being renewed - eg behind the piston furthest from bleed valve - particularly the forward piston on rear caliper and the bracket end if the SMC. So it is importnat to do something to flush that out and replace with with new. So see-sawing the double pistons, tilting and pumping the SMC, flexing the brake lines, and the clutch - pump the lever a few times - agitate the clutch and hold the lever in so that the slave piston is pressed in, then without relaease the lever, open the bleed valve so that the slave piston pushes the fluid out. Repeat.
