There's lots of commonality across the VFR and ST1300,
Good to know. Thanks. Does the VFR have a linked brake system with SMC as well?
'98 thru '09 has the linked brakes.... Plenty of us (including me) rip those out and replace with different forks, standard style separate brakes with the separate rear...Good to know. Thanks. Does the VFR have a linked brake system with SMC as well?
The 1200 is completely different to everything else! I just bought one as a do-up project so can speak with authority.Doesn't the 1200 have a shaft drive as well?
The general arrangement is practically identical; the VFR forums aren't awash with a lot of tales of seized SMCs like the ST forum but that may be due to less "all weather" riding on the VFR. The 6th gen VFRs (02-13) have simplified LBS with the right calliper being driven solely from the hand lever, but the left middle piston doing the same as the ST. The 5th gen VFR LBS configuration is identical to the ST.Good to know. Thanks. Does the VFR have a linked brake system with SMC as well?
I forgot that one but yes you are right, the centre rear piston is driven from the SMC on the VFR, where it is the outer rears on the ST.From memory the rear caliper pistons are connected opposite to the arrangement in the ST13.
It looks in good nick. More pics to come I hope?![]()
He he, you gotta post up photos....![]()
