- Joined
- Mar 18, 2006
- Messages
- 430
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2025 Miles
- 003355
Putting my fairing back on, I noticed that my vertical adjustment is not operating.
That is: When I press the up button, the motor whirrs for a while and then stops. If I press the down button, the motor whirrs for a while and then stops.
But the headlamp does not move. I believe that it is supposed to move the entire unit - bulb and reflector - both at the same time.
There is also a white adjuster knob on the back of the unit - which doesn't have any effect either. So I am guessing that the gear mechanism has stripped teeth and is stuck in the current position.
Does anyone know exactly how this works and can it be serviced please ? I cannot see how it is possible to separate the parts. There are some latch type tags all around the unit. I tried to ease one away and the plastic is now so brittle, it just snapped.
Edit - I have seen a second hand one - it appears to be a bayonet type fitiing into the headlamp body. Maybe if I can get it out, I can see what it screws into.
