I think your right about the fluid neglect, The conditions the slave cylinder is exposed to with hot then cold and damp is a horrible exposure level. As well as the bleeder is at the top of the cylinder.
There were lots of large displacement bikes with cable clutches over the years, Goldwings didn't have hydraulic until 1984, and there were numerous 900s/1000s/1100s with cable clutches in the day. However, engines were getting more powerful over time, and large touring bikes were getting heavier, so it was probably inevitable that cable operated systems would be replaced by something more powerful.The introduction of hydraulic clutches are what made it possible to overcome the higher spring forces required of clutches needed for heavier motorcycles with larger displacement high torque engines. Without them there would be the need for ridiculously long lever throw and/or the need to have forearms like Popeye.
Thank you all for the responses. It does appear to me that it is an issue with the clutch not disengaging completely. I did previously replace and bleed the fluid as it was pretty dirty and slightly low. Since I changed it, the fluid level has stayed the same. The linkage seems to be pretty smooth operating, but I will clean it all up and lubricate it just to be sure. The clutch lever does seem to be a bit loose so I will definitely take that all apart and check the bushing. And I did just change the oil. Unfortunately, its looking like I may end up having to replace the slave cylinder, as it did have a small leak so there is probably some corrosion in the cylinder. Good to hear its not my riding abilities. The link to how to replace the cylinder didn't work but I can just do a search. Lastly, does anyone have a source for a replacement slave cylinder and gasket.
Thanks again.
| 3 | CYLINDER ASSY., CLUTCH SLAVE 22860-MCS-000 In Stock | $85.89 | ||
| 4 | GASKET, SLAVE CYLINDER 22862-MGJ-D00 In Stock | $4.63 |
Thanks Pete. Already have the parts rdered.Hi again @Beajae:
The best sources for parts would be: Partzilla.com, Discount Honda Parts and lastly, your friendly local Honda dealer (which will likely be expensive and require a back order). Here is the relevant page from the Partzilla,com website showing the CSC which attaches just to the left of the oil filter. This job is much easier if you remove the oil filter first BTW.
The clutch slave is part #3 (the assembly has a little box drawn around it) and it is in stock at a cost of $86 and the gasket is also in stock and costs around $4.68:
3 CYLINDER ASSY., CLUTCH SLAVE
22860-MCS-000
In Stock$111.23
$85.894 GASKET, SLAVE CYLINDER
22862-MGJ-D00
In Stock$6.07
$4.63
Also - you will need several (I'd get about a dozen of them) copper crush washers for the banjo fittings. Do NOT reuse the old ones - they might leak and are cheap and easily available.
Pete
Air does rise doesn't itThe bleeder needs to be at the top. The problem is that the inlet line is also at the top instead of at the bottom. If the bleeder was anywhere but at the top bleeding would not be very effective at removing the air.
Of course, which is why the bleeder needs to be at the top.Air does rise doesn't it
Including As well as the bleeder is at the top of the cylinder in a statement that is detailing factors believed to contribute to slave cylinder failures gave me the impression that the bleeder's location at the top of the cylinder was also being considered a contributing factor. I was pointing out that it needs to be located at the top to be effective. The same is not true of the inlet. Having the inlet at the top contributes to ineffective flushing and it would allow that process to be more effective if the inlet was at the bottom.I think your right about the fluid neglect, The conditions the slave cylinder is exposed to with hot then cold and damp is a horrible exposure level. As well as the bleeder is at the top of the cylinder.
Do you know when the last flush was? If not, most would suggest doing one, so you're sure when it was last done.Clutch fluid looks new & clear
I had the same issue, cleaning and re-lubing the shift linkage fixed the problem. Since the bike is new to me, I also noticed that there is a decent amount of "play" for the shift lever before it actually changes the gear, so "preloading" the shifter helps as well.- thread bump -
I seem to be having the same rough shift issue, going between 1-2 and 2-1
Clutch fluid looks new & clear, level is to the top of the window mark when the bars are turned to the right.
No leaks at the slave cylinder
Engine oil looks ok, about 3000 miles on it
Have not inspected the shifter linkage.
Any thoughts or recommendations?
Thank you! How does one do that? Remove the bottom left fairing, and go from there?Before you go too far - try lubricating the shift mechanism joints
Have a look through the below thread. It is for an ST1100 but if you have an ST1300 they are so similar that the thread can be used.Thank you! How does one do that? Remove the bottom left fairing, and go from there?
Thanks, what does that mean exactly? Push down twice, kinda like the trigger button on a camera?Preload shifter.
Apply upward or downward* pressure** to the shift pedal in advance of making a shift. When you are ready to pull the clutch lever and make the shift you increase the pressure to the amount that you would normally use to effect a shift.Thanks, what does that mean exactly? Push down twice, kinda like the trigger button on a camera?
Definitely follow the article that Andrew linked, when I did my ST1300 I had already removed all of the bodywork as I was doing a LOT of maintenance at the time, I'm pretty sure you only need to remove the bottom fairings.Thank you! How does one do that? Remove the bottom left fairing, and go from there?
