Midweek Fatigue, Mar 4th, whatever year that is...
Nah.
Just lower the lift, then lower and remove the jack, and she'll just roll right off the back, with a little push.
You got this!
Yeah, thanks. It was sketchy, those seconds that make your heart pound. It’s not wide enuf to balance effectively.. there’s that 6-8” ramp down transition that leaves your feet flailing. One too far tip, already half a foot off the ground, narrow footing… yeah that doesn’t have any concerns…AND breaks my number 1 rule which I thought I already learned from the incident that made it my #1 rule.. which is… now, if I even think.. that.. it maybe a little tough… to do this.. let’s see, if I do this. FULL STOP! Wait, Get Help!! it’s not like I can’t get help.
But nooooooo, yeah it did it, without incident, but my brain says, next time, plan help.
But look, she’s on the ground. I put 20 miles on it, runs better, handles better.. nothing leaks, the burn off wrap smoke made for some funny stop lights.. have a good mind to run down to Daytona in the morning. Ready for some highway speeds and check out the new manufacturer offerings there at the speedway. See how many STers I can see.
Our guest room is now cat proof
(never, EVER, throw away scrap pieces of hardwood that might someday turn out to be useful in some unforeseeable way)
Good work on your solution.
But that other.. I have those same pieces of wood that are now petrified! Problem is, I feel that way about most things.. stuff. Not hoarding problem but that.. someday be useful, absolutely hits home with me!
I bet you're one of those wild rebels that runs around the house with scissors in both hands and your underwear inside out on your head.
Soooo jealous.
Scissors! Underwear inside out!! Hell yeah, but we don’t run around the house!
let me be clear.. too old to run, if I ran.. I think I would get hurt worse than the other stuff! 🤣
Sooooo nothing to be jealous about.
I'll try and remember to post a photo of my rolling, wood scrap box (also made entirely from scrap wood.)
It was supposed to keep everything neat, tidy, organized and easily searchable.
For a few minutes, it likely was....
Yeah, I get it. the stuff accumulates faster than it can ever be used. I have the same problem, even AFTER I built a couple very useful tool storage / organizer units (which still make me happy every time I look at or open them) entirely from surplus / scrap and recovered materials.
I considered trying to do my most recent tool storage unit entirely from leftovers but in the end it was faster and easier to use fresh materials for most of it. The top is a leftover piece (made use of the panel I ruined when I measured wrong on the dressing bench) but everything else was new material.
After I get back from FL (if I go) I'll have to reorganize and sort through the various boxes of bits and pieces, choosing what to keep and what to throw in the burn pile and what to throw in the "to the dump" pile. All of the plywood scraps will go into that latter category, as burning composite materials is a big no-no due to the massive chemical releases that triggers.
It sounds like you back it off while you are sitting on the bike. I have the same lift and that is a recipe for disaster as the lift is not wide enough to firmly plant your feet as you wrote. I stand on the floor beside the lift and roll the bike backwards while balancing and steering it and feathering the front brake to control the speed.
Thanks,
I did back it down..
I considered the walk beside but she’s too tall and I have no confidence, that I would succeed, rather survive that maneuver, that front tire can slide. At 150lbs, with a bad knee, coming off of a bunch of bed rest.. No, I need help, I have a 20 yr old son..
so I will build my side walks 😂
As long as you can flat foot then it’s easy, to the point that I think just build 2 ‘side-walks’, a ft wide, they lay on both sides and would store efficiently, sure it’s been done before.
Anyways, shakedown done, I did 198 miles today..
It was a great day, definitely an improvement in ride performance, still needs work, improved from feeling skittish around 80, no confidence to go faster- when I first got it. Now it feels good thru 90 but no confidence past 100, I’ll talk that stuff over in the tech areas.
Really pleased though with performance, 80-100 around semis felt controlled, not lucky. And it could do it faster than I wanted to 😆
I probably scanned 100 if not a thousand bikes for an ST.. I saw none, no wait I saw 1 on the way back home, while sitting at a large intersection, then across the way.. a red ST, he saw me about the same time and I could tell he was also excited to see another. Maybe he’s on here..
The hwy pegs have one drawback for me, that I will deal with, while super comfortable and if I didn’t have that range, I would of had to take more breaks, but.. when up there and need to return, I cannot find the pegs, longer in that position, the worse it is..
once your foot lets go off the peg, wind takes over.. from that point I have to look down to find the peg, something that needs to be automatic second nature or that action will kill you.
Anyways, getting it dailed in.
Nd
