no, the muck on the outside does not indicate that there is anything wrong with the bearing.
But I notice that there is a band around the spacer on the left hand side - the bottom photo. A band like that is typical where the seal rubs on the spacer - which suggested that spacer has previously been put in the other way round. I think it may be the wrong way round now.
Here are the spacers on the axle as viewed from the front. It doesn’t show the left side of the bike very well - but the measurement is only 4mm on that side (right side of the photo, left side of bike)
Note that the spacer on the left of the bike (right in the photo) has only 4mm sticking out. Yours has more than that.
That suggests that the spacer may be in the wrong way round. If so, that means that the short 4mm side is sitting inside the dust seal, and is not pressing against the face of the bearing - which means that your wheel can move laterally on the axle. It should be the 10.1mm side that sits firmly onto the inner race of the bearing. It can’t because it is 6mm too short. Some of that space will have been reclaimed by squashing the dust seals. It also means that your fork is splayed out too far and (probably) your caliper bracket is catching in the brake disc surface. If you look at the end of the axle bolt with the large hex socket on the right hand wheel - the axle is slightly proud. It should be flush.
That is a lot to conclude from one photo, but I think I am right and would definitely check it out. You’re the chap that was complaining about high speed instability ? That might be the reason. If so, you will probably need new dust seals.
Here is my front wheel showing the spacers fitted correctly.
See what I mean ?
I’m curious - did you get any other sensations - eg when leant over in bends - like you get when the rear tyre is squared off ? Or perhaps a bit of scrapping noise that you are not able to pin down.
I can’t remember. You may have to remove a caliper bracket to drop the wheel far enough to remove the spacer. If it was me, I would take the wheel out completely, confirm that the spacer I in the wrong way round and check for other damage. I suspect that the seal will be ruined, because it is rotating with the hub but has been clamped against that flange on the spacer which is fixed - although since it hasn’t been clamped properly, maybe it was rotating. Check the inside of the fork leg at the axle hole. Check the face of the bearing that the seal has not been melted into the bearing. The bearing has a seal so is probably ok.
If you find that my analysis from that single photo is correct, you now have an idea of the skill level of whoever fitted the front wheel - probably at the last tyre change. You would do well to assume that the same level of skill has been applied to everything else. Brakes would be my next concern and the rear wheel drive splines and tightening sequence, then any electrical additions.
Keep asking the questions.
