Gas Tank "gurgling"
Shenandoah Valley Virginia
Came home from a ride yesterday and parked the ST1300 in the garage. Heard a "gurgling" sound coming from the gas tank. Opened the filler cap and saw some air bubbles. The gas was not boiling but seemed to have trapped air rising. Could this be gas flowing into the lower tank? Never experienced this on the ST, no leaks or gas smells. I have had boiling gas working on my old Kawasaki Z1 though. Any opinions or advice would be appreciated.
Thanks, Dale
It also makes a really eerie sound which frightened the life out of me the first time that I heard it late one evening. A slow intake of breath, through your mouth and let it activate your vocal cords. You’ll get the idea.
One of the few replies that may be worth something. These replies to posts have become attempts to be humorous. Thanks Holm.
While it is always possible it is not likely that you will discover that the fuel cap vent is malfunctioning. The temperature of the engine actually goes up for a while after the engine has been turned off. This residual heat radiates to other parts in close proximity to the engine, such as the fuel tank which sits directly above the engine, and is not quickly dissipated because there is no airflow as the motorcycle is stationary. This is referred to as heat soak. Some of the fuel in the section of the tank that is directly above the hot engine reaches a temperature where some of it turns in to an actual gas as opposed to remaining liquid gasoline. That gas bubble then rises to the top of the tank as it is now lighter than the liquid fuel. What you are hearing is that gas bubble dissipating in to the empty cavity above the liquid gasoline. This does not normally increase the pressure in the tank enough to cause the fuel cap vent valve to open. As the heat dissipates and the temperature drops no more gas bubbles are produced and the burping stops.
